Segmented Hollowform #2
steve antonucci
>Various woods, Cherry burl collar...
Please feel free to comment...
steve antonucci
Re: Segmented Hollowform #2
Stuart Johnson
>Steve, You might want to brush up on your sanding.
A warm fuzzy.
adrien
Reminds me of a coconut...
>Is it a coconut with a turned collar?
Nope, but I saw coconut first too
steve antonucci
>It's a hollowform that is comprised of thousands of random length, wide and thickness that have been formed over a pre-made form.
The materials are readily available in any workshop.
Steve
Sawdust papier mache?
severe static problem in your shop!
Dick Coers
Barnacle encrusted wood float.
GalenV in Iowa
>Not sure what you mean by random pieces over a form. Did you happen to take a photo before turning?
Galen
Dah! Opened #2 before #1- Now I see the light!
GalenV in Iowa
I like that Dick- I'll send him some Cling Free
Somewhat Tongue in Cheek
steve antonucci
>I did these two pieces in response to the flack about the AAW Direction towards post lathe work. I thought it would be fun to present these two as "turnings", even though they really weren't (no matter what I decided to call them!)
Piece #1 is a series of small squares that I gang cut from popsicle sticks, which took about 30 minutes once I figured out how to do it safely. The balloon that I blew up sat on my work bench on a roll of duck tape and I would work in small sections to keep the pieces from sliding around. Once the glue set up, I could do some more. Usually, there was 5 minutes of work per session, over the course of a week or so... I had the collar already turned, so I just built up the neck until it fit the collar.
Piece #2 also started with a ballon, which I covered in Bondo to give myself a working chance at popping the balloon. Once the bondo set, I just used shaving (but not from the lathe as I reported, but my bandsaw :-) and glue to cover the whole mess. I took another collar from a vessel that I had cut through (because I don't use a laser hollowing system) and blended it in.
So you see, you too can be a woodturner, and you barely even need a lathe... I bet I could make the collars with a drill pres and a carving knife for the next one...
Social commentary is so much fun...
S
