Slightly OT - Viscous damped hinge/rotary
David Belser
>I'm kicking around a WHI (Wild Hare Idea h/t Charlie) and I'm looking for a source for (cheap/surplus) viscous damped parts. These are the slow-motion hinges and such that involve a spring and high viscosity fluid that causes the part to move or open at a slow/constant rate.
I've seen cheap versions used in folding pens handed out trade shows and also for a lid on a cheap calculator.
But searching the web, I'm coming up empty except for manufacturers of high quality hinges for use on aircraft etc.
Any help or suggestions appreciated. (I'm sure someone has a box of these just lying around :)
- Dave
Re: Slightly OT - Viscous damped hinge/rotary
charlie belden
>Blum has something that looks like a larger version of the Butter Ball Turkey Pops Out When Done button thing that causes cabinet doors to close quickly to almost shut - then slowly the last 1/2 inch - part of their BlumMotion idea. About $5 a pop, they ain't inexpensive.
Just took apart an old Slide the Top Aside To Get To The Keyboard cell phones, looking for the vibrator motor and eccentric weight. Turns out this phone didn't have one, but the spring loaded slides parts have some possibilities for sliding parts on a piece - slide up, slide down - or slide left, slide right. Could be used for a sliding locking mechanism on a piece - limiting range and distance of motion to one axis and maybe an inch or two of movement - right up your alley.
Re: Slightly OT - Viscous damped hinge/rotary *LINK*
David Belser
>Thanks Charlie. I was myself looking for vibrating motors a while ago and found this place with a fair variety and not too expensive.
I'm actually looking for an actuator that will extend about 1/4" slowly when released, hence some sort of damped spring mechanism. I could work with a quarter or half turn rotary motion that was also a slow damped spring.
I'm going to search for novelty pens tomorrow or maybe I can find a communicator type lid opener that will do the trick. Problem is I don't have any way to judge how much force I'll need.
- Dave
Vibrating Motors
Curly Smith
>Try a search on either "rotary viscous damper" or "rotary hinge damper".
One possible source is McMaster-Carr at the link.
Miniature Rotary Dampers
Thanks!
David Belser
>Looks like ACE controls has what I want, now I just need to find someone that will sell small quantity.
