>This is a glass half-full, half-empty situation. The half-empty view is one of my customers' father's not able to turn anymore (virtually blind). The half-full view... She sent me a few pieces of African Blackwood from his stash, figuring I could use it better than letting it rot.
So my situation is this: One of the pieces is suitable for a small hollowform. I want to mount it to a glue block for hollowing. Will thick CA and accelerator work? That is my preferred method of mounting on glue blocks because, well, that is what I was taught.
That is definately a half empty/half full scenario.
As far as glue blocks, I do prefer "thick" CA but often don't use accelerator. Two reasons, I think it cures so fast some of the strength could be compromised-don't know if it's fact or not-or just a "wives tale". And two, as you cut the piece away or cut through the glue line a "pocket" of uncured CA can be exposed and start slinging back at you. If the two surfaces aren't perfectly flat and the outside cures fast it can seal in some glue on the inside. If accelerator is used apply to the opposite surface, glue one-accelerator on the other. Don't stick the two together and then spray it. It will only cure the outside.
I usually apply some CA, let it sit for 5-7 minutes and turn it. Haven't had any problems.
>I too use the CA on one surface, accelerator on the other method. That's what Lyle Jamieson showed us back in Feb 2008. I just wasn't sure about the blackwood and CA. I don't work the stuff because of it's endangered state but since this was given to me..... Sure is pretty.
>I too use CA - sometimes. For quick and dirty - small. But when in doubt I go to Titebond. It must dry overnight but I've never had it come apart - even with the oily woods. Just my $.02.
>Another vote for Titebond. CA is said to be rather brittle and prone to failure from impact (catch) loads. Not suggesting that you would ever get a catch. I use CA to stabilize hairline cracks, but any real joinery gets Titebond.
>Probably so. If the bat were glued with CA and used to hit a baseball, the impact load would be likely to cause a joint failure. Would be less likely to fail if glued with Titebond.
>Grain orientation is another thing. If you are gluing flat grain to flat grain, no problem. If you are gluing end grain to end grain, or end grain to flat grain, there can be problems. Surfaces need to be dead flat, but even then you may not get a good hold. For small pieces, say 2 x 2 inch, no problem, but longer pieces are more of a problem. The way to get around that is to make a matching recess and tenon (1/16 to 1/8 deep) on the block and the turning piece. I would only use yellow glue, not the CA. One thing with the CA is that if you use the accelerator, it only works on the outside part, not the inside (note numerous spots on glasses). This is especially true if you are using the thick stuff, you should let it sit for a couple of hours, or better yet, over night. I would let the yellow glue sit over night as well. I also prefer a glue bead around the outside perimeter. Usually I do this with squeeze out rather than adding another line of glue.
About the baseball bats: I called up Franklin glues to ask them some questions about glues, the eurethane glues (gorilla glue) specifically. They said one test they did was to make baseball bats by laminating pieces using both eurethane glue and titebond. The eurathane glues delamainated every time.
>I agree with Robo. I mount things like this between centers, find the orientation I want and then turn a tenon. Not only does this locate the wood exactly where I want it, the tenon gives a much larger and stronger glue surface. I use epoxy for any wood I am suspect of.
