Wild Hare Idea - Tight Rope Walker 1: Progress
charlie belden
>In another attempt at a piece with actual movement I've been playing with the idea of a piece strung on monofilament line connected to verticals with turned elements on the ends, one end of the line moveable up and down. It's a familiar idea - the little toy clown on the unicycle who rides back and forth on a tight rope.
Could go with a familiar traditional turning idea - or a turned clown. Was leaning towards the clown idea but once I got out some wood and started turning I of course went the other way - a more elegant piece. The inconguity of a semi-formal, somewhat delicate piece, sliding back and forth on a tight rope seemed as if it would add an inconguous HUH? to the piece.
To add to the confusion, the top finial is in a ball and socket joint - with an internal counterbalance - so as the body rocks left/right and fore/aft, the finial will always remain vertical. It's not obvious that that's what's happening, but the mind will pick up on the fact that something "just ain't right" well before the logical part of the brain identifies what "ain't right".
The finial and bottom "icicle" are african blackwood, the top "collar" is probably bubinga and the body - just something I had that was about the right size.
If I can get the balance on this thing right I'll do columns on both ends, one with a hole through it for a spring that will control the up and down movement of one end of the tight rope. Will do africal blackwood base and cap for the uprights and "up/down" handle.
As always, comments, suggestions and constructive criticism welcomed
