200+ woodworking book reviews
Pen Finish
Pen Finish
Bob Moffett
Pen Finish
Bob Moffett
>I am making some pens for a friend of mine to give as gifts. What do ya'll recommend for a durable, high gloss finish that will last?
Re: Pen Finish
Re: Pen Finish
Ken Oakley-Sunny St. Cloud, Fla.
>My preference would be Deft Lacquer. I do know many pen turners prefer CA glue.I am sure it needs to be thinned to be applied.
Re: Pen Finish
Re: Pen Finish
David Walser
>I recommend CA glue over more traditional finishes, such as lacquer or shellac. CA seems to be much more durable. Do an internet search on "CA Pen Finish" and you'll find several articles and videos on how to use CA glue to finish a pen. There seems to be as many different ways as there are turners who use the finish.
Re: Pen Finish
Re: Pen Finish
Bill Neff
>As a relative newbie to pens (turning in general) I've found the method by William Young to be easy, fast & does a great job. He uses a BLO & CA glue combination. You can finish it off with a plastic polish.
Re: Pen Finish
Steve Kubien
I've been playing with something... LONG
Steve Kubien
>I do not know why but I have had inconsistent results using straight CA, or a CA/BLO technique. Straight CA with the lathe running has always ended up with runs or a very rough surface from bits of paper towel grabbing (I suspect). With CA/BLO, I was getting dull spots, shiny spots, some ridges from the med CA setting up to fast...all manner of bad-ness. Here's something I tried and, so far, it is working well for me...
Sand your blank as fine as you are happy with, going with the grain after each grit (this is very important!!!!). I go anywhere from 1500 to 12000 micromesh or 4000 abranet. Turn off your lathe and leave it off. Drizzle 2 or 3 drops of thin CA along the length of the blank, put the bottle down quickly and spin the blank with your hand to spread the glue all the way around with paper towel, then wipe off excess WITH THE GRAIN. You have got to work fast (!!!) here or you will have all manner of badness. Let it all set for a minute or two. If there are any ridges, sand them off and go again. If not, go again anyway. 2 or 3 times is plenty for my tastes but if you want a solar-flair-type-gloss (and the platic feel that goes with it), keep going for 5 or 7 coats (whatever floats your boat).
Now, my Nova 1624 does not have a handwheel and even if it did, I think it would be uselss for this as I am a lefty. Turning the blank while it is one the mandrel is tough, especially since you need to move quickly. I drilled and tapped a block to fit over the threads on my headstock which I can grab with my right hand and use to spin the works while using the paper towel in my left (remember, I'm a lefty). I round the block so it doesn't grab and bite my hands while turning. This is the best shop-accessory I have ever made including when I still did fl*t work. I love this improvised handwheel. I install it before i put my pen mandrel in place and it does not come off until I am ready to pack my batch of pens. Heck, if I am doing spindle work, I will leave it on.
It should go without saying but I will say it anyway... Only work on one piece of the pen at a time (in the case of a two-piece design like a slimline, Baron, euro etc).
Well, it works for me.....
Steve Kubien
P.S. the picture is the handheel thingie (sorry for the technical terminology) I made for my 1624.
Re: Pen Finish
Bob Moffett
Re: Pen Finish
Bob Moffett
>Thanks for all the good information everyone. It sounds like CA & BIO is the way to go.
Re: Pen Finish
Re: I've been playing with something... LONG
Bob Macgregor
>Steve,
Do you spin it backwards by hand? If not, do you have any problem with your handwheel unthreading itself?
I have a Craftex 18/47, also with no handwheel, and wouldn't mind having a way to get a grip now and again.
BOB
Re: Pen Finish
Re: Aahhh Steve, why don't you just ....
Jamie Donaldson
>...stand on the back side of the lathe while doing this process???
Re: Pen Finish
Steve Kubien
Steve Kubien
>No Bob, I tighten it done pretty good. If it loosens during a spin, I just spin it the other way and re-tighten before the next coat.
Re: Pen Finish
Steve Kubien
Dammit Jamie!
Steve Kubien
>There you go thinking again! If you are not careful that kind of activity will start spreading.
Honestly, it never occured to me and I am not sure it would work... No matter what, my Nova still does not have a proper handwheel so my improvised one is needed. Doing what you suggest would result in fewer gymnastics though. The second and I think bigger problem is that I would have pick up all the crappola on the other side of the lathe to be able to stand there. As it is now, I could kneel on the back side of my lathe and still have to lean down to turn or finish something.
Thinking?.... What are you thinking!
Steve
Re: Pen Finish
Tom Vensel
>Hi , Just in case you didn't know Nova does sell a handwheel for the 16-24 lathe .I bought mine at Woodcraft .Cost about $30. I think every lathe should have one . Tom in S/E Ohio
Re: Pen Finish
Steve Kubien
Steve Kubien
>Hey Tom,
Ya, I did know that. I just never got around to picking on up. Lazy and cheap. Yup, that`s me
Thanks,
Steve
Re: Pen Finish
Re: I don't know why....
Russ Fairfield
>I don't know why standing on the back side of the lathe always comes as such a revelation to most woodturners. There are a lot of things that are easier to do because you can see better. The only problem is that they have to be done Left Handed. The bigger problem is that most people push their lathe up against the wall
Re: Pen Finish
Steven Antonucci
I bought the handwheel for my Nova 3000
steve antonucci
>it wasn't expensive, and it threads in to the other side of the spindle. Go buy one, and never look back...
Steve
