bowl disaster, could have been worse
>Well so much for trying to get rid of the tearout in this bowl. I was actually doing pretty well. I soaked the tearout prone area with thinned lacquer. Then used my sharpest gouge, a higher speed on the lathe and slow feeding to reduce it to a couple of small 1" or so patches. I soaked these with thin CA and still didn't get rid of every last one but had it down to sanding with 80 or 100 grit. Shear scraping on this one didn't improve the finish quality any over the sharp gouge and may have even added a little bit of tearout.
I worked on the inside and had still had the same 2 areas but is seemed a little less prone to tearout using the 40 degree gouge. I had thinned it all down to the last 4 inches when I heard a funny noise. I shut the lathe off immediately. The bowl had cracked almost 6 inches down the side right through the tearout prone area. Fortunately I wasn't running the lathe very fast. I opened the crack and poured thin CA in and then closed the crack.
I'm not going to sand waste time sanding this one. I'll just put it on the shelf and watch it for the next 2 or 3 years and see how the glue holds. I don't dare sell something like this. If the glue does hold up over time I might sand it down and keep it for myself.
Bummer. It started out as an 18" bowl and by the time I got rid of the bad areas it was down to 15 1/2 about 6" deep. It would have been a nice piece. Fortunately I cored out the inside so I will get another stab at turning a piece from this. Needless to say I will stay well out of the line of fire.
By the way Keith's Gage'T bowl measuring device works great. I've used it a lot lately and it's really fast. It easily measured to the bottom of this piece. It is 1/2" thick.
