A55 Smoothing Plane
Inertia
Inertia
Inertia
Paul Zerjay
>If you are hollowing a large form that's very heavy, is it better to have your belt a little on the loose side, rather than have it real tight? Just by chance, I had my belt loose, and was hollowing a piece of Bradford pear that was probably around 40 lbs. I was using brand new kelton 5/8" hollowers (Great BTW) and I was able to slow down the lathe unless I took care not to take too big of cuts. This got me to wondering if this was a good idea to hollow with a loose belt rather than take the chance and have a big explosion with all the inertia behind a heavy hollow form.
Re: Inertia
Re: Inertia
Mac Ray
>It works for me Paul,have always had my belt just a bit loose...be careful not to get it too loose tho....can be a real pain.....
Re: Inertia
Re: Inertia
>I don't have my belts really tight either but in reality I think the explosion would be over before the belt would have time to slip. The main reason I leave the belt a hair loose is for bad catches. If the belt slips it may not jerk the tool out of your hand. In reality I don't get bad catches anymore just those occasional stupid ones when you aren't paying attention.
I am learning to use the McMaughton system and with the learning curve comes catches that will either stop the wood or bend the tool. Leaving the belt loose allows the wood to stop. I've only had 3 of those catches but I could see how they could be really nasty if you had a 5 horse motor driven by 2 or 3 belts. Something would have to give and it would probably be the tool.
Re: Inertia
Re: Inertia
Paul Zerjay
>That's exactly what I'm talking about John. I think a loose belt would make the piece either stop or slow down before a giant catch would cause a major explosion. I've learned to keep my belt a little loose while coring. This is why my belt was loose in the first place when I started hollowing the piece I was originally talking about.
Re: Inertia
Re: Inertia
Jim Rutten
>I always have my belt loose after a big Thanksgiving Day meal (oh, comon. You were thinking it. I just said it.)
