Loc-Tite Loosening?
charlie belden
>I have the JET VS mini/midi which required an adapter on the head stock end to accomodate the SuperNova2 chucks. Adapter would sometimes unscrew when I stopped the turninbg rather than let it spin down to a stop.
SO - after the last episode, which spun the lip of a hollow form into the tool rest - I LocTited that sucker (Blue LocTite). Hasn't come loose since.
But now I want to use the face plate that came with the lathe - which meant removing the adapter. WRONG! Bent my knock out bar trying to get it off.
HELP - need the Secret Method for unLocing LocTite - and please don't suggest heating things to 400 to 600 degrees F. . .
Other possibility is to buy another faceplate - with the diameter and thread matching the adapter. Sources?
(Every solution seems to create a new problem)
