Sandpaper recommendations for small turnings?
Joe Pack
>I do a lot of turning, particularly small items (pens, keychains, stoppers, etc.) I have been using, and have been satisfied with, Norton 3X that I bought at a great price at a Rockler store. My supply is just about used up, the great price is no more. So, I am looking for another good price on Norton 3x (can't seem to find one) or for recommendations for a different paper.
I use mainly 120, 180, 240, 320, but sometimes use a bit coarser or finer if needed. I cut my sheets into strips about 1" wide (found this to be much cheaper than buying in roles so far, but rolls are okay too if they are economical).
Can you recommend a sandpaper equal to or better than the Norton 3x, especially one I can buy at a very good price?
Re: Sandpaper recommendations for small turnings?
Carole Valentine
>Give Bruce a call at The Sanding Glove. He can fix you right up.
>I can't. I love my 3X. I do a lot of smaller projects. The 3X has a stiff enough backing to fold and let you get into tight areas, It sands very clean and lasts a long time. I switched from Klingspor gold rolls to the 3X. I have tried 2 other top brands and can't remember the name, one of them I think was Eagle made in Japan. It was excellent paper but the backing was too flimsy and it fell apart too easily.
If you find another paper I would be interested in trying it also. I do use Abranet that I get from thesandingglove.com It is a mesh sandpaper that works great on woods that clog up other papers.
Russ Fairfield
>There is a lot of cheaper sandpaper on the market, but you will always get what you pay for, and have to sadrifice something for the lower price.
I have used the sheet sandpaper from Industrial Abrasives for years. It is a good quality sandpaper at a reasonable price, but it has a thinner backing paper than the Norton 3X. Other than that, it is as good as anything I have used.
Re: You might also try
Russ Fairfield
>You might also try the sandpaper that is sold by Ace Hardware. It is "Gator" brand or something like that. It is a good quality sandpaper for less money than the Norton 3-M
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>Yes, Call Bruce at The Sanding Glove. He has just received a shipment of Norton A975 that he is going to be cutting into disks. The Norton A975 is equal to or superior to the 3X (Hard to tell from the Norton literature.) But the A975 is a seeded gel ceramic with a similar soft backing that last forever. I consider it the best sandpaper on the market after testing sandpaper for over four years. It may not be the cheapest initially, but because it lasts so long it is one of the biggest bargains on the market.
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>Everybody has his own preferences. I use AstroDot from Woodchuckers in Canada. Also, unlike most turners, I like to sand under power at extremely fast power sanding rotational speeds using a very light touch. I learned the technique here from Bill Needow( spelling?)
