McNaughton coring system
>Well I've cored 14 bowls now. I have 2 or 3 problems. The most obvious is knowing how deep the cutting tip is. I guess the only way round that is either lots of experience of the lazar attachment. I got the parts I need for my lathe/mill so maybe I'll have time to build a nice lazar attachment.
The other problems are, I run into several times during the cut when the thing simply won't cut. You can't push the tool in any further and it simply won't cut. This often happens after I've pulled the tool out to clear the shavings. I think maybe a shaving is getting over the tip but I'm not sure. Usually I will clear it and push back in and maybe wiggle the tip and it starts again.
The other problem I'll take care of monday. The set screw that holds the two parts of the tool rest together won't stay in place. I'll just get one of the locking set screws and that should take care of the problem.
