bevel angle
Karl
>My gouges have cheeks. what am I doing wrong when I'm grinding?
bevel angle
Karl
Re: bevel angle
Sean Troy
>There is no way to really know without seeing what your doing. Where are you located so that someone nearby might be able to help you in person.
Re: I suspect that you mean .....
Jamie Donaldson
>... the nose (cutting tip)of the gouge has been ground away, leaving protruding wings on the front that are very prone to catches, as you probably now know! That part of the tool shaft is thinner than the wings on the sides, and thus is ground away faster than the sides. Lighten up any pressure, and skip more quickly from wing to wing, thus reducing the grinding away of the tip area(and bevel).
just when I thought
karlkulp
>I was getting a handle on jig sharpening it started. I ground off the offending protrusions and resharpened.
If I understand your advice I need a much lighter touch at the grinding wheel. Particularly around the toe tip
Re: just when I thought
George Van Beynen
>Karl, I have developed the habit of grinding the right then the left wing, after which I do a light blending pass over the tip from wing to wing for a finished grind. Works for me.
karl
>That's exactly what I did today. Gauges got ground sharp and the edges held up nice. I've learned that careful sharpening pays off.
