table saw blades for segmented work
gary clarke
>My woodworker II blade is about done for and I am wondering what all you segmented turners are using for cutting segments on a cabinet saw that has a 10" blade.
gary clarke
Re: table saw blades for segmented work
Russ Fairfield
>I use a 96T blade by CMT on a sliding miter saw and a Freud 50T Combination saw of the Delta table saw, and I can't tell the difference. They both make the same gluable surface that is flat and without any signs of blade vibration or wayward teeth.
I think that any blade of similar quality on the same machines will give similar results, including your Woodworker-II.
gary clarke
>thanks Russ
Bill Crommett
>I also use a Freud 50 tooth blade.
Texian
>80 tooth Freud.
