Rikon tools
BQ in VT
>Has anybody used any Rikon tools? They have a new radial arm drill press that I was looking at, but I have not found any reviews on it.
Rikon tools
BQ in VT
Re: Rikon tools
>I've used a lot of Rikon Lathes, they are excellent. I bought a bottom of the line Rikon 12" disc sander. It's OK, worth the money and I think it's as good or better than the other $200 sanders but it's not as good a quality as I would have liked. Still I think it will do the job it was designed for.
Re: Rikon tools
JohnKyler
>I have been looking at the General International radial arm drill press.
Not sure about the Rikon.
18" Bandsaw is an excellent value
steve antonucci
Re: 18" Bandsaw is an excellent value
Ken
>My 1st lathe was a Ricon mini,stll have it an love it.Not to mention there service,fantastic
Jim Tusant
>I have a 12", 14" and 18" bandsaws. The 18" is the Rikon. It is the best bandsaw I have used for the money. It is a real value and a workhorse. However, I was not that impressed with their larger lathe. They have great service if needed. Hope this helps somewhat.
Re: Rikon tools
Steve Kubien
>I haven't used it but I got a very favourable response about their larger lathe from a larger individual we all know and love in Kutztown, PA.
Steve
Re: Rikon tools
Jim Sebring
>You must be talkin' about that fella with all the 'Turning Muscle'. One kool guy ;-)
Re: Rikon tools
Fog Tanner
>I have one of their mini lathes. I made a stand for it and decided that since I was going to have to paint it, I would get rid of the hideous green and white one the lathe.
I completely disassembled it leaving only the spindle in the headstock. When I started stripping the paint off, I found what a poor casting it is. In some places it was OK (would not cut your fingers), and in others it was really bad (could be used for a sanding surface). From the machining marks, they must dip it in paint and then machine it. The paint really fills in the bad casting. I got out the Bondo and sandpaper and proceeded to get rid of all the roughness.
It now looks like a different machine, a real lathe with a nice smooth surface. You can't even tell where they missed the machining on the headtsock, it now looks one peice. It only had an hour on it when I painted it and now has quite a few more. I improved a few things on it when I put back together. Some of the retainers were minimal and I didn't care for the way they did the switch wiring. It runs good and I prefer it over the Jet copy of the Vicmarc.
After seeing the quality of their castings, I would be leery of any their larger machines that contain cast pieces. And the headstock being off on all the ones I have seen does not give you the warm and fuzzies about their design or machining.
Fog
Re: Rikon tools
Rick_Allen
>I have no experience with the Rikon Radial Arm Drill press.
I have experience with a different brand RADP. I did not understand the need for the RADP. Mostly I found that the RADP would deflect in use.
I would suppose that you have a particular need for a RADP. If the RADP is just because it looks like a great tool I would look to see if a standard DP could meet your needs.
