Have a question? Ask Woody!
Keeping work in process moist
Alex Yeilding
>While it is nice to turn wet wood to finish or to blank stage for drying, what do you do if your work is interrupted for a few hours or few days? In the case I'm envisioning, you have done preliminary shaping of the outside, thus removing any anchorseal or the like and exposing endgrain. And it is too thick to airdry without checking. Do you reseal with anchorseal or equivalent, or wrap with damp towels and plastic bags, or what?
Re: Keeping work in process moist
Steve Kubien
Steve Kubien
>Alex, it seems you are talking about two very different situations....
If my intention is to turn green to finish...it depends. If I haven't started hollowing (whether bowl or HF), I will anchorseal the outside, know full-well that I will have to, virutally start over. If I HAVE started hollowing, I will bag it in plastic as tightly as I can. When I can find my shrink-wrap, I will use it instead of the bag.
If we are talking about a dried blank which was previously anchorsealed, I will leave things where I am and not worry about it. Think about it, if you anchorsealed it, you probably will have let it sit long enough that it is dry and not likely to move on you. If that is not the case (you anchorsealed a blank and didn't leave it long enough to dry and think it will move), then I would follow the plastic bag route.
Does that make sense? Do I need another coffee?
Cheers,
Steve
>Alex I use white plastic garbage bags. It works well for a few days. Much longer than that and mold starts. Some woods will mold faster. I use the plastic bags if I stop for any reason even for a few minutes. It keeps the wood from warping or drying. I've kept larger blanks stored this way for several weeks. These were blanks that were roughed out kind of thick.
Re: garbage can and shavings
Dave Mount
>I have a garbage can in the shop that I use for hauling out shavings. If I have to stop partway, I just throw some of the wet shavings I just made in the bottom, put the workpiece on them, then throw some more shavings over the top and put the lid on. I haven't done any actual experiments, but my unsubstantiated opinion is that I get less mold with the garbage can plus shavings approach than when I use a plastic bag.
Because cleaning wet sawdust out of the bandsaw is a hassle, I often cut several wet blanks into rounds at one time, then turn them over the course of several days. Rather than reseal them with Anchorseal, I just put them in the garbage can with shavings and I've held them as long as four weeks with no damage. Most of these have been hard maple, the lumber of which is prone to staining if not allowed to dry. However, I haven't had any staining problems storing wet bowl blanks this way. Any growth that does start has been surficial.
Best,
Dave
>Dave I may give that a try. My shop garbage can needs to be replaced. It' plastic and falling apart. I'll get one with lid and give it a try. After 2 days my last blank had lots of mold. It didn't hurt it, it was just hairy stuff on the surface but I don't need any extra "penicillin" in my shop
