Re: O.T. Just one time...
Paul Zerjay
>It does. One line clockwise, the other counter-clockwise. Can you imagine how hard it is to hold the head between your knees, and have line in each hand while trying to load both lines (in different directions) simultaneously? If you don't do it simultaneously, one line will cross over the other and trap it to where it won't come out as you need more line. Once you've spent half an hour wrestling this monkey, try getting that reloaded spool back on the shaft without it exploding into a pile of spaghetti. I am actually a big fan of the motor. I bought this model at a pawn shop two or three years ago (not knowing how many hours it had on it then) and it has performed well with all the abuse my son has given it. It takes better than two hours of use to complete my line trimming needs each time we mow.
