Doh!
Doh!
Doh!
Jim Rutten
>I flipped around a bowl to finish the bottom last night. I had been putting coats of Watco Penetrating oil on and letting them dry overnight between coats so it had been about 4 days since sanding. Picked up my spindle gouge to worry away the tenon and...nothing. Wouldn't cut worth anything, turned the speed up thinking that might help...nothing still crappy. Went back to the tormek and touched it up ...still bad. I was starting to get a little worried. Picked up a parting tool (I know this is not the right tool but figured I could worry it away a little at a time)...nothing. Picked up a bowl gouge...same result. Had all of my lathe experience and training just flown out the window. What in the heck was going on here? Looked over at the on/off control and as many of you have probably already guessed the forward/reverse switch was on reverse...
DOH!
Sometimes I amaze even myself at the depths of my stupidity. Oh well, as the saying goes "even my worst day turning is better than my best day at work"!
Re: Doh!
Re: Never admit to anything!!!
Dave Anderson (PacNW)
Re: Doh!
Re: Doh!
Jim Stoppleworth
>Been there done that. ..........and spent moments trying to figure what was wrong.
Re: Doh!
Re: Doh!
Michael Lee
>ALSO Been there, done that. (While I was trying to help my daughter learn to turn) Maybe we should start a new club?...if I hold the tool upside down...yep...that should work.
Dave, I assume you are a politician? Washington DC? :-)
Mike
Re: Doh!
Re: Doh!
Cyril Griesbach
>I often sand alternating between forward and reverse. Ended in reverse and the next rough out wouldn't cut for crap. Took a while but finally the light did go on.
Re: Doh!
Re: Doh!
Don wilcut
>Jim, we've all been there. Some will not admit it but I have done it.
Re: Doh!
Re: Doh!
Ken
>I ain't,nope not me never.You do believe me RIGHT ???
Re: Doh!
Re: I don't have a clue what you're talking about!
Jamie Donaldson
Re: Doh!
Paul Kramer
Never done it --- couldn't
Paul Kramer
>My old Delta midi didn't have reverse. Now (I just got the Delta 46-460) I'll be able to share this wonderful experience with you. I just have to wait for the fun to begin.
Re: Doh!
Did that while teaching a class
>One of my students had the lathe in reverse. I sharpened the gouge, it wouldn't cut. I got my gouge it wouldn't cut. I resharpened my gouge, It wouldn't cut, then I saw the switch, DOH
Re: Doh!
Re: Doh!
>Been there, done that. Been laughed at. Laughed at myself.
OTOH Can someone explain why the Forward arrow on my DVR Lathe points to the Right and the Reverse arrow points to the Left? Those screens will display most anything. Could they have come up with a more clear display for forward and reverse.
My son and I went to Arrowmont for a turning class with David Ellsworth. My son was 15 and the star of the class. Someone near him was turning on a Poolwood. He couldn't get his chisel to cut and asked John for help. John looked for a second and Said, "you have it in reverse." and went back to turning. The guy came up to me a complimented me on John's manors. He thought John missed a perfectly good opportunity to give him grief. I asked John, he said "that wasn't funny, it could happen to anybody."
Re: Doh!
Re: Doh!
Carole Valentine
>Barry, how in the heck could you do that on a DVR??? The damned thing beeps at you and delays the start for what seems like 10 seconds if you have it in reverse. It is an irritating feature, to me.
Re: Doh!
I did it while starting a demo
keith zimmerman, Normal, IL
>And I flipped the switch without even realizing it. It sure is a strange feeling when everything you try has no effect and YOU CAN'T CUT THE WOOD!
keithz
Re: Doh!
Re: Doh!
Jim Sebring
>The DVR message and delay must be either government or Microsoft inspired - are you really, really, really sure you want to run this hummer in reverse? If I didn't want it to go in reverse, I would probably push the other arrow button, thank you very much!
Re: Doh!
Me too Jim
Dave Peebles Lyons, Ohio!
>It was right after I got my Oneway with the short extention on the outboard side.
I put my first piece of wood on the inboard side between centers and turned the outside. I then took it around to the outboard side to do the inside. I did remember to hit the reversing switch. Everything went great. I finished the piece and shut down the lathe. It was about 3:00 AM. Remember... this was the first day. :)
The next day I put another chuck of wood inboard. Same story as yours. It did take a few moments and a few sharpenings until it finally dawned on my what was happening. I actually LOL. Happy that none of my buddies were there to give me grief.
Yes.. I to am a proud member of that Bass Ackward club.
Best wishes,
Dave
Re: Doh!
Re: Doh!
>Carol, I have an older DVR, the program is dated 2002. I just tried it and it starts in forward and reverse identically. It has a circular set of opposing arrows on the touch pad that switches it back and forth and it plays its little beeps, but its the same each way.
The controls can be annoying. When I press a button, I want it to DO something, not think about it and play a tune and announce "LOW RPMs, Try Again" every time. (Of course the RPMs are low, you were OFF.) It's only a few seconds, but sometimes it strikes me as recalcitrance. Or insolence.
I glued a foam rubber sticky pad on the off button so I can find it without looking. Just a little button to make it "tactile". A good improvement when things are a little hairy.
Re: Doh!
Re: Doh!
Carole Valentine
>No delay before starting in reverse? And no warning scrolling across the screen? Darn, maybe we can trade! LOL
Re: Doh!
Dick Hines
Re: Doh!
Dick Hines
>Jim, bet every one who has foward/reverse on their lathe has done this. I know I have. If they tell they never have , they are not useing the reverse on their lathe.
Re: Doh!
Re: Doh!
Bill Crommett
>It is gratifying to know that we are a bunch of intelligent turners who can really use our brains to finally figure out what problems we have gotten ourselves into.
Those who haven't been able to figure out why the to0l won't cut have probably sold the lathe and don't knom how to use a computer.
We are select !
