>A friend asked me to turn this for him. He's going to Thailand and got the one on the right from a guy while he was there last time. He wanted to give him a new one just like it. He brought me what he called desert ironwood. Really pretty stuff but turns like Bacote, no shavings just dust. Turns very clean and requires little sanding. It is oily. There isn't any finish on this.
>I won't have time to shoot these correctly. I have to be at work at 4:30 in the morning to shoot a 30 foot tall sculpture in a hospital. I promised my friend he could pick these up first thing tomorrow so I used my Admiral Oven shooting booth. :) Just use the right amount of bounce cards and one tungsten light in the oven hood. Set your camera white balance to Tungsten and then adjust to the correct exposure.
The camera was on a tripod, exposure 1/2 second at f8.
>I forgot to mention that the oven should be set at 375 degrees. Eddie, A photographer would never survive without junk food. I'm off to find a doughnut to get me through the shoot this morning and then we'll have a good breakfast.
Some time back you wrote and artical that described a simple but effective light box. in that write up (correct me if I'm wrong) I believe you recommended using a halogen utility light for the light source. Within this thread, you referenced tungsten as the light source. Is the tungsten bulb cooler than halogen? Is there a tungsten bulb that can be a drop in replacement for halogen?
The reason I am asking these questions is because while I am using a 500 watt 60 hz 120 volt halogen utility lamp, this lamp gets too hot and is (I believe) a fire hazard.
>Dan The lamp I used for the stove is actually warmer (redder) than quartz halogen. Using my rediculously expensive color temperature meter the bulb measures 2400 degree Kelvin. Quartz lamps are usually somewhere around 2700 degrees Kelvin. The tungsten setting on your camera should be 3200 degrees.
What this means is the quartz lamps are a little warm or slightly red/orange as the camera see it. However I have found the difference to be barely noticeable even shooting on a neutral gray background which shows color shifts a lot.
2400 degrees starts to shift even further yellow or orange. I did make a slight color correction in photoshop to clean up the white back ground which was slightly orange.
You don't really need a 500 watt lamp. If you have a tripod and your subject isn't moving, the shutter speed on your camera can be set to any speed that will give a good exposure. That means that instead of using lets say 1/30 of a second at f16 with a 500 watt light you might be using 1/2 second with a 100 watt light. This assumes that you are using a manual or aperture priority setting on the camera. If you use the auto setting the camera will change the f stop as well as the shutter speed when you go to the weaker light and you won't have enough depth of field to keep the whole bowl in focus.
The fire hazard is just one of the reasons I prefer a translucent photo booth. The light is outside the booth. I've found that if you keep the lights a foot or more away from things fire is not a problem.
Don't ever leave them unattended. If something gets close they will set it on fire. I use 300 watt lights and have run tests. They will ignite a black piece of paper when placed 3 or 4 inches away. I would guess wood shavings might ignite if left long enough. I often place a white nylon diffusion panel a foot or so away from the light without any problems.
