First turning project EVER...
Grant in Iowa
>Hi all,
I am a longtime flatside WC'er. Yesterday, I found an old Rockwell 46-111 lathe with a frankensteinish belt setup for sale. I bought the lathe and drug it home to my heretofor latheless shop.
Missing only two belts, I quickly got it up and running....at least temporarily until I refine the drive mechanism. I'll post a picture of the lathe and belt-train below.
Anyway, here's my first project completed! Never picked up a gouge in my life before today. I really didn't pay much attention to proportion, I was more worried about not goofing up in irreparable ways.
The sides are under 1/8" until you get close to the base. The inside is finished as nicely as the outside.... promise.
Regards,
Grant in Iowa
Re: First turning project EVER...
The lathe
Grant in Iowa
>My new to me lathe is an early to mid seventies Rockwell 46-L11 (part of the more generic 46-111 lathe family). This is the lighter duty of two models Rockwell made during that time.
I paid $150 for the whole schmear. Belts were missing, and I had to pick up some "get me by" turning gouges.
It is what it is....
The belt train kluge...
Grant in Iowa
>A previous owner decided (rightly) that 4 speeds just were not enough. So they set the original Rockwell 1/2 HP motor to run backwards, and added two additional stepped pulleys. Time and pressure have "tweaked" the jackshaft to an angle. It isn't really as bad as it looks, as the board the jackshaft is attached to is sticking out towards the camera more than it needs to, so while the jackshaft isn't horizontal, it isn't off all that much. Close enough for belts to compensate for now.
I plan to fix this in the near future before much more turning is attempted.
Regards,
Grant in Iowa
The back side of the lathe
Grant in Iowa
>Here's a shot of the back side of the lathe. You can see the upper step pulley and indexing pin for fluting work.
It isn't a Oneway, but ya gotta start somewhere! At least the headstock bearings seem tight and smooth. I did notice the outboard threads on the headstock. I have no left handed faceplates though.
Anyone know what the threads are on the headstock on this machine? I did measure 8 threads per inch and the outer diameter appears slightly smaller than 1". I suppose I could put my calipers on there I guess.
Regards,
Grant in Iowa
Looks good. Welcome to the addicted crowd.
adrien
Your off to a great start
Bernie
Rob Wallace
Re: First turning project EVER... *LINK*
Rob Wallace
>Hello Grant in Iowa!
This is Rob in Iowa......
.....just wondering where you are located? (I'm in Ames.)
I would like to invite you to our turners group meeting coming-up on this Sunday afternoon (July 26th) from 1:00 to 4:00 pm in west Ames. In addition to our normal show and tell, display of member's new tools, etc., the program on Sunday will be a demonstration (by me) on what I learned in a hands-on class I took from French woodturner Alain Mailland last month. I'll be turning one of his 'flowers'. We typically meet on the last Sunday of the month. Let me know if you are interested in more information about where we will meet and how to get there. If you can't come on this Sunday, but can make any of our future meetings, just know there is a standing invitation....get in touch in advance so I can send you the information.
There are at least 5 other woodturning clubs covering areas in Iowa - you should become a member of at least one of them to be able to meet other turners in your area. I hope your transition from the flat side to the round side continues in this direction. You've already accomplished a very nice turning! You may also want to check out my Woodturning Links web page at the Site below....
Good to know there's yet another new turner in Iowa!
Cheers,
Rob Wallace
Rob Wallace's Woodturning Links
Another case of turners disease in Iowa
GalenV in Iowa
>So far I have not found a cure for this disease as it spreads across the state. Only thing I have found is you just keep spending money and the cure is no closer. Kinda like going to any doctor now days.
Just like an acoholic I am not sure we want a cure!
Welcome to the meetings.
Galen
Re: You should hope that the threads....
Jamie Donaldson
>..are 1"X8 so that you have a variety of available accessories that will fit. Excellent job for a first turning, and you are now on a slippery slope!
That's the model I started on
>My dad bought it for me in 1959, when I was ten years old. I had it right up to the shop fire in '99. They were all light gray in those days. The pulley arrangement we rigged up was just the simple 4-sheave single pulley, but we mounted the motor on a cast-iron motor plate that had two studs on the sides that pivoted in matching cradles attached to the cabinet, so the pulley end was free to tilt. This made belt-changing a breeze. A tension spring hooked under the front end of the motor mount kept adequate tension on the belt, although if I were to do it again, I'd probably put a solid spreader in there for tension.
Now all you need is a few thousand dollars worth of tools and accessories and you'll be all set. Welcome to the slippery slope.
don lewonczyk
>Very nice turning. Make sure you keep and date the piece so you can compare your new turnings along the way. You were lucky to get an older lathe like that with the indexing pin still in the headstock. I couldn't order one for mine because they are not available anymore so I borrowed one from a friend and a machine shop made one for me, $35.00,1/6 of what I paid for the lathe.Good Luck from chigger infested south middle TN. DonL
Way to go Grant !
Don Orr
>You're off to a great start-I think you're a natural !
Re: The back side of the lathe
Ben Ragusa, S Jersey
>I have the same model and can confirm that the threads are 1x8, a common size for many accessories.
Got a Grey One
Al Kapocius
>I've got one of the older grey models. I slapped a masonite panel on the back side of the stand to keep the shavings from collecting inside. Another "improvement" was to add a line to lift the motor, going down to a hinged foot pedal at the stand base as a safety aid. I use it to ease into the lopsided logs until the roughing gouge can balance things out.
Enjoy.
Al Kapocius
