electrical question
Eduardo
>Hi well need to know if a speed regulator(for a router)will work on a lathe (1-1/2hp motor 220volt) seen one in a mail order house thanks
electrical question
Eduardo
Re: No.
Jesper, Denmark
Re: electrical question
Frederick Nelson
>The short answer: most definitely not!
The motor in the router is of a type called a universal motor. It contains brushes and may vary its speed dependant on such variables as voltage, whether DC or AC, or timing of the AC frequency.
The motor in the lathe is of the type called an induction motor. It is hard-wired for the specific speed it produces, and while it can have its voltage varied (within specific ranges, ie. 110 or 220 volts only) it will still produce the same speed. If you reduce the voltage in an attempt to reduce its speed, the motor will still try to produce the same speed, and probably burn itself up in the process.
For the average woodworker, the only to vary the speed of an induction motor's output is through belts and pulleys.
I hope this answers your question in as simple a manner as possible. The use of a speed varying device such as for a router on a lathe is a really Bad Idea.
Fred
Under full overcast in Eastern Missouri
Eduardo
>Thank again for the info, will resort to pulleys lol
adrien
>Interesting Fred. How do they get variable speeds on the lathes that have that capacity?
Don Evans
>He was referring too and assuming rightly that the motor in question was a 1 phase motor.
The lathes that have variable speed are doing it with a 3 phase motor installed.
Don
Frederick Nelson
>Most of the electronically variable speed motors on today's lathes are indeed multi-phase; usually three. Play with the phase angles, the voltage, and the wave-forms, and you get infinitely variable speed of rotation. Oddly enough, most of these variable speed induction motors are DC powered. It is just that the "DC Power" they are fed is not the filtered wave-form that runs our computers (for instance). It is a carefully tailored and timed collected of three wave-form inputs to achieve the necessary power and rotational speed desired.
On a single-phase induction motor, you can vary the speed and power output by varying the AC frequency you feed the motor. Unfortunately, this only works over a very narrow range of frequencies within the motor's ability to handle the heat produced by operating out of its specifications. Too much variation from the 50 or 60 Hz (European or US) AC power, and you burn up your motor. Personally, I place all of this speculation very, very firmly in the "DON'T TRY THIS AT HOME!" category, and leave it there. You'd be well-advised to do the same.
Purchasing a motor, with its attendant electronics, that is designed for variable speed is a different story. There are plenty of messages on this board about the folks who have successfully upgraded their lathes to electronically variable speed by replacing the motor. All it takes is money.
Fred
NOT turning (at the moment) in Eastern Missouri
Very well explained, Thanks!
Jorge Castaneda~Downeast Maine
