Bleached Box Elder
Bleached Box Elder
Bleached Box Elder
Bernie
>Speaking of bleaching box elder
This bowl is 12" bleached and finished with waterbased wipe on poly
The red is a deeper red and the white a nice white after beaching.
Comment welcomed
Thanks for looking
Bernie
Re: Bleached Box Elder
Bob Rogne
>Looks great Bernie. What did you use to bleach?
Bob R
cliff
>very nice can you explain the bleaching process?
George Van Beynen
>Bernie, this is a very well designed bowl. Your bleaching process and the following finish have made this a very attractive piece.
Bernie
>Cliff,
The wood bleach is a two part system that you can buy at Woodcraft.
I sanded the bowl through 400 painted on the thin solution, usually
two or three applications will do. This does raise the grain so I go back and resand with 400 and proceed through 1200. To keep it white
I used a waterbase poly finish.
Hope the helps
Works great on cherry and walnut too
Don Evans
>Very nice, wish I could score some of that wood.
Don
Steve Kubien
Thanks Bernie
Steve Kubien
>I think whenever I get my hands on some manitoba maple with that sort of colour I will certainly give this a shot. I love the effect.
When you say it works well on cherry and walnut, have you got a picture(s) of the results? I am curious and I have very little of either woods and I am reluctant to try it until I know what to expect. Ya, I'm a big chicken.
Thanks again,
Steve
fredbear34
>When I read the title of your post my instant reaction was "why the heck would someone want to ruin a piece of box elder with bleach?" Curiosity got me to open the post and I've got to admit, I was wrong again. The red is outstanding and I enjoy this piece. Have you used this technique over enough pieces (and time) to know whether the red remains as brilliant for any length of time? Very interesting, thanks.
Steven Antonucci
Way cool...
steve antonucci
>Does the bleaching make the red deeper or does it just stand out more? Hard to tell...
Steve
Re:It's too bad the red will still fade.
Jamie Donaldson
Steve Kubien
But Jamie...
Steve Kubien
>...using an exterior version of water-based poly (which ought to have some sort of UV inhibiter) should slow it down, shouldn't it?
Re: But Jamie...
>Steve It probably does but it takes so long for a piece to fade indoors that it would be hard to tell. I did a test with Box Elder out doors under direct all day sun and the red faded withing 36 hours even with spar Varnish.
I have several Box Elder vessels that are on a glass enclosed shelf out of direct sunlight and they look just fine. One is over 2 years old, the other it maybe 4 or 5. The might have lost some of the brightness of the color,it's hard to tell. They still look pretty good.
Russ Fairfield
>3 to 5 years and it's gone in normal indoor lighting. The only way to preserve the color is air tight and total darkness. Anything less and it will fade.
Re: Thanks Bernie
Bernie
>Sorry Steve no pictures, I have given those pieces away.
The cherry and walnut will fade 5-6 shades lighter,a nice
effect for a rim.
Bernie
>Like stated below this is a 8 month old piece that is displayed
inside and still looks the same as the day I finsihed it. The
poly helps along with were it is displayed, no direct sunlight.
Thanks for the comments
Re: Way cool...
Bernie
>Steve it seems like the red gets alittle deeper but the white really
gets white and the contrast is striking. Also I sand to 1200 to 1500 grit so this piece really looks like a piece of marble.
Thanks for looking
cliff
>thanks bernie, sounds simple enough gonna try it.
