Departure From Round and Brown
charlie belden
>Using 3 centers on each end of a blank and turning arcs, you can do three sided stuff. And if you rotate the centers on one end a quarter turn you can add a twist. With an eccentric chuck you can turn some pretty odd things as well. Then there's the eccentric hemispheres / plates.
But what about if the surface you turn a hemisphere into were basically two wedges - flat on the back but in opposing directions on the face to be turned? The angled "step" at their interface would break up the look of the hemispherical concavity, introducing a degree of confusion due to the ambiguity of what you're seeing. Looking straight down in the attached example you'd see a round red spot. But tilt and 'or rotate the piece and "round" breaks up .
I'm certain this isn't something new - too many turners trying so many different things for so long. But it does have a lot of possibilities for at least getting past the "round" of Brown & Round. Vary the depth of the hemisphere, the location of its center relative to the two wedges interface, three wedges, . . .
Anyone have actual examples they've done or links to pieces that use this idea?
