Curvature of a classical column
Michael Bush
>I'm starting to plan a writing desk one of my sons and I will make together for him. We're going to put ionic columns at the four corners as legs. I know there are classical standards for how these things are supposed to be proportioned, and I've got those somewhere in a book. What I'm concerned about is the slight curvature. Does anyone know of a template or some other guidance out there for getting the bulging shape right?
Re: Curvature of a classical column
Re: Curvature of a classical column *LINK*
Dick Coers
>I just watched a Nova where they talked about the Parthenon. They said the radius of the curvature, of the columns, was about 1 mile. Maybe the link will be a little more helpful.
column dimensions
Michael Bush
>LOL. I had a little smaller scale in mind! But I might be able to use that chart and a calculator and get pretty close to what I'm looking for.
(Since you posted that link, I realize I used the name of the wrong order. I'm not fixing to carve those scrolls! I meant Doric.)
Russ Fairfield
>The reason for the bulge is that the parallax in our vision makes the sides appear to bow inward. Our vision is corrected by putting a slight swell in the column with its maximum diameter at 2/5 of the height from the base. However, we need to reverse this and make the swell 2/5 down from the top because we are making table legs that are viewed from the top, not the bottom as we would see a column.
I doubt that a 1-mile radius whould be enough for a table leg, but 1/8" will look "just right", and keep them from looking like hour-glasses.
Michael Bush
>Wow, that is a really important insight about the difference in perspective.
Tony - Memphis
>There are several books at Dover that describe the various orders. Mack Headley did an article for FWW on applying the proportions to a tea table I believe. The Benjamin Asher book (or is it Asher Benjamin?), Chippendale's book, etc. all describe the various orders. I recently found a source online that I'll have to hunt for that described them as well.
Not sure that any of these describe the raidus of the column, but in one of my sources, I know I have seen a diagram similar to what was shown on the PBS show mentioned (great show). It showed the width at a given height.
Tony
http://www.classicist.org/workspace/pdf/Ionic-Order.pdf
http://store.doverpublications.com/0486222365.html
