Many Trails # 2
Carl Barton
>You might recall the first Many Trails bowl I made awhile back. As I was making that one I was already starting the second one. I finished this one yesterday.
This one is at the capacity of my mini lathe, 9-3/4 dia. by 5-3/4in high and 229 pieces. Made from walnut, maple and purpleheart. I used purpleheart for the symbol because I had ran out of walnut and used what I had on hand.
The feature ring joints are much tighter this time around and I chose a different shape. This was the first time I tried this shape and I did not get as clean cut inside as I wanted. In fact I was so busy shaping the outside that when I did start the inside I almost blew the bowl out. But all in all I am pleased with the results this time. Not bad for doing on a mini.
As always your comments are most welcomed.
Carl
