About bearing noise on a Jet 1442...
Glenn Madsen near San Francisco
>Noisy bearing at the headstock, right where the chuck attaches to the head.
Can one lube the bearings, and does it do any good?
Is changing the bearing something a relative novice mechanic can do?
The lathe is lightly used, bought new in 2005 summer. Right now, I'm doing spindle work for Windsor chairs, and the noise is oppressive. Not wanting to do anything that damages the lathe, I'd like some guidance from someone who knows. There is no budget to upgrade to the larger Powermatic, or Nova, or any of the other 'wonder lathes'. Yes, they're better, but not needed right now.
Your advice willingly and gratefully received.
Re: About bearing noise on a Jet 1442...
Rick Allen
>It is possible that the bearings are damaged. These bearings are not the type which can be lubricated (or ever need lubrication). The bearings can be replaced by a novice.
This is a Reeves drive variable speed lathe. The drive system on this lathe is very often a source of noise. You can and should do maintenance on the reeves drive on a regular basis. This is cleaning and lubing the pulley and pulley shaft. Inspect the belt for wear and replace when needed. The pulley halves may also need replacing, especially if the service for these parts has been neglected. If the pulley halves wobble or the movable pulley half shaft hole appears elongated or otherwise worn then replacement is indicated.
Back to the bearings. If you are sure about the headstock bearings being the issue then replacement is the answer. The bearings are designed to be replaced and are fairly inexpensive (especialy when purchased from a bearing supply instead of Jet). There is a procedure to be followed so get that information from Jet if you can't find it in the manual.
>Thanks, Rick.
Do you know if that material, the bearing replacement method, is posted on the Web? My manual is long buried where my posterity may find it decades from now...
The belt looked in good condition when I opened the cover. There is that dark grey lint collected in some quantity there. Methods of replacing the belt, and the part number for getting one from the Napa auto parts place were found in a Google search before posting here. I don't think I have a Reeves issue. The high pitched squeaks I'm getting, I get when I turn the headstock shaft by hand. I suspect it's a dry bearing.
It may be time to find a local helper for things mechanical.
Here's the manual online (pdf format)
Jim Rutten
>http://content.jettools.com/manuals/m_708358k.pdf
Re: Thank you, sir!
>You think I'd have been able to find that, wouldn't you? ;)
