>I have a general 26020 VS. I have moved and when I set up the lathe and pluged in the lathe it will not run. I have checked to make sure there is power to control panel on the back of the lathe, and the line from the VS controller is fine, there is continuity on all the lines to the control panel. there is nothing coming up on the LED panel.
>Every time I think about Ruth and the General reminds me of when I first started reading posts from Ruth. I thought the General was the man in her life. LOL! What a dummy I was.
>Did you remember to press the "On" button down below the control panel?
Sometimes the VFD gets confused or kicks out. The remedy is to cutoff the power for at least 30 seconds, then re-connect and press the "On" button. The forward-reverse switch should be on "Stop" during this.
If that does not work, call General, they will be happy to help.
>There is a green on and a red off button on the right side of the base containing the motor and supporting the shaft.
There is no reset button on the VFD itself. It resets by removing the power completely for >30 seconds.
The drive (at least on mine from around 1998) is a Square D Altivar. The manual is a book about � inch thich and as unintelligible(sp?) as they can be.
