stave making jig
peter kolb
>I am looking for a plan to make a shop
made stave jig for a miter saw.
Any links out there?
Thanks for your help.
Peter
stave making jig
peter kolb
Peter
Re: stave making jig
>Peter I'm not sure what your looking for. The only thing I've used and I learned this from 2 other friends, was to put a round head screw in the end of a block of wood. This is clamped to the fence to act as a stop for the width of the miters. The screw makes it sort of micro adjustable.
The only other trick was to figure out a way to safely hole the wood flat on the table. My friend George had a spring loaded clamp made from wood. Another friend simply used a pencil, eraser down to put pressure on the cut off piece. I used a thin piece of wood as a spring and clamped it to the table.
Curly Smith
>If I correctly understand your question, you could build a variation of Kevin Neelley's COMPOUND MITER SLED
Rob Wallace
>Do you really mean SEGMENTS or STAVES?
You would not normally cut staves (a ripping operation) on a miter saw....
.... you likely would have to build a ripping sled with stock hold-downs, so you could slide the pieces through the tablesaw with the blade tilted to half of the included angle of each stave segment.
Can you be more specific about what you intend to do?
Rob Wallace
Texian
>Ditto what Rob said. I cut straight and compound staves on home made sleds on the table saw. Would not attempt them on a miter saw. Suppose it could be done, but would require everything very securely clamped in place before the cut. Repeat, very securely clamped!
