Remote Switch for PM 3520b
Jorge Castaneda~Downeast Maine
>Hi,
A couple weeks ago, while turning a Y shaped crotch piece, and having to speed it up, at some point, besides the huge amount of air being moved, it down on me that I did not want to cross the fire plane to be able to turn off the switch, I ended pulling the plug off the wall.
So I ordered a remote switch for the mustard monster and yesterday the sad news about the fellow turner in Waterdown Ontario, made me feel better about having spend a little over a hundred bits on it, maybe he was trying to reach the switch when the piece of wood flew and hit him.
So today the switch arrived, straight from Powermatic and there are no instructions of how to wire it.
Have any of you have done that? I would like to hear how it is done.
Thanks in advance
Jorge
Re: Remote Switch for PM 3520b
Dick Hines
Dick Hines
>Go to the table of contents and look under remote switch. All the information you will need is there.
I built one a couple of uyesrs ago and love it. There may be some information at www.mustardmonster.com
Scott Hurley in N VA
>I added one to my Jet 1642 over a year ago. I just took the 1642 switch out of the headstock, tapped the remote switch wires into the existing switch (parallel connection), and put the switch back in.
Word of warning - keep it clean, if possible. Mine quit working (just the remote switch) a few months after I bought it. I opened it up and found 2 sets of contacts. I switched the wires to the other set of contacts, and the switch has been fine ever since. Later I read (here, I think) that that kind of issue is due to excess dust. I now keep the remote on the far end of the lathe from the headstock.
Scott
Steven Antonucci
I have a simple box
steve antonucci
>My remote switch is a simple box with a switched outlet. It sticks with a magnet on the back of my lathe, and I plug it in, and the lathe into it.
No wiring involved...
Steve
BE in Electrical engineering, not desire to burn out his lathe
Re: Remote Switch for PM 3520b *LINK*
Ian
>jorge,
pages 40 and 41 of the owners manual show how to hook up the switch.
if you can't find yours, the link will take you to the pdf on the powermatic home site.
IAN
remote switch wiring
>Jorge It's just wired in series with the main switch I think they've already given you directions. What I do recommend is to dissassemble the box and seal every opening. I have had a problem with dust getting into the switch itself. You have to actually dissassemble the switch itself for cleaning. Sealing the box to keep the dust out should help prevent this problem.
Why can't you just...
Paul Zerjay
>switch the receptacle the lathe is plugged into? I think this is what Steve is saying.
Re: Why can't you just...
Bill Howatt
>You can do that, at least for an emergency. However, there are people who will tell you that needlessly cycling the power on an VFD by using the switch as a second off switch is not the best idea. I'm sure others will disagree.
If anybody cares, I usually leave mine plugged in all the time unless I know I'm going to be away from the lathe for long periods or if there are thunderstorms in the area.
Bill
Thank You All
>Thanks everybody, I'll install it in the morning when I am fresh and fully awake.
Ian,
Thank you much, I could not find my manual, so I apprecciate the link..
Steve,
I thought that the variable speed control may not like to be switched like that, so I opted to use Powermatic's own solution to be on the safe side, I am no electrician.
Thanks John,
>Good heads up.
I'll seal it good, I am always for preventive maintenance.
>Bill What's so handy about the remote switches is they have a magnet on them so you can put them where they can be most easily accessed in an emergency.
DavidWalser
Allow me to present an alternative theory: In an emergency you want your hand (or your knee) to simply hit the off switch without having to look for the switch. That's much harder to do if the switch is moved from place to place while you're turning. For this reason, it might be better to have the "stop" switch mounted on the tailstock end of the lathe -- where you'll always know where to find it. As with most things, YMMV.
Bill Howatt
>You do raise a valid point. I made a moveable start/stop/speed knob box for my General 260 because I didn't like the location of the buttons on the stock lathe. It is fine for spindle work but if you have a scary bowl problem it's not ideal.
It is best to have an off switch on either side of the headstock. In my case, I normally put my control box on the ways wherever convenient and I put an extra Off button where the speed pot used to be located so I have Off control on either side of the headstock.
A couple of design points if you are inclined to do this with your lathe:
If you have on/off pushbuttons already, there is a good chance these will have the full line voltage on them, not 24V, so be careful of your wiring practices. Since I know about such things I made a 12V control system to avoid high voltages on the remote cable.
I put the speed pot on the control box; not because it was the best location but so it was near the one and only On button so I could see the speed setting when hitting the On button.
