200+ woodworking book reviews
What wheels do you have on your grinder
Jim K in Trappe, PA
>Both the rough and fine wheels on my grinder are the originals, and need replacement. The fine wheel has been OK, but the rough wheel isn't aggressive enough.
I'm thinking of putting on Norton 46 and 80 grits. I don't even know what's on there now....I'll find out when I take them off.
If you like what you have, what grit do you use? What manufacture?
Thanks,
Jim
Re: What wheels do you have on your grinder
Barry Turner
>I have a Delta Slo-speed grinder (the 90+# one)with a 60-grit pink and a 120-grit white, both from Woodcraft. I love the 60 pink, but might swap the white for a 100 if I had it to do over.
Oneway wheels
Dave Peebles Lyons, Ohio!
>Hi Jim,
I replaced my wheels a couple of years ago with the 8" wheels that Oneway sells. I use a 54 and an 80. I have found no need to go any finer.
These replaced the wheels that came on the Woodcraft 1725 rpm grinder. There was a lot of life left on the original wheels. I think I gave them to Carol at Indyfest to get her going with her turning gear. They were ok, but groved easily. I am really pleased with the wheels I have now.
Best wishes,
Dave
Bill Howatt
>I now have an 8" 1725 rpm grinder but I was using the while-wheels from LV on the 6" 1725 rpm grinder and they were a PITA since they wore very quickly which meant a lot of dressing.
For the 8" I am now using an 80x Norton blue wheel which LV now carries. I really like it since it doesn't wear as fast but stays "sharp"; good balance between wheel wear and dulling. I guess the term is good friability for the desired use. I use it mainly for sharpening already shaped tools.
I use the coarse grey wheel that came with the 8" grinder for general shaping and for scraper sharpening. I did use the fine grey wheel for sharpenng my gouges and it does work OK with a light touch but I like the blue wheel much better.
Bill
Bill Neddow------WebKitFormBoundary+w+uCg3oRve3I+f
>I have 2 slow speed grinders (1725). On one is the original grey wheel (54 grit, I think) for general shaping plus a Norton 80 grit for tools that are fairly well shaped but dull. On the other, is a Norton 120 wheel and a diamond 180. Most of my sharpening is done on the 120 grit wheel, but when final cuts are to be made, I use the 180 diamond, which almost hones the tool. If I had to choose two wheels, it would be the 80 and the 120.
Norton 80 and 120
keith zimmerman, Normal IL
Fred W Holder
>For some time now, I've been using diamond wheels on my Woodcraft Slow Speed Grinder. I normally do my finish grinding on bowl gouges with the Tormek, but the diamond wheels seem to be working pretty well. On the left wheel, I have a 100 grit diamond wheel from Andre Martel in Canada. The right hand side is a 360 grit diamond wheel designed for polishing stones. It works fine if one doesn't get too aggressive and overhead it, I'm told by the manufacturer.
The one advantgage of these diamond wheels is that the wheel is 1-1/2" wide, which making sharpening much easier. They also remain flat and don't seem to load up like the old white wheels. I have both wheels fitted with attachments to use the Tormek jigs on the dry grinder. This allows one to rough grind on the dry grinder and them move to the Tormek to finish grind.
I'm still evaluating these wheels and am not actually ready to write a report on them. I would be interested in hearing from others who use the diamond wheels.
Cindy Drozda------WebKitFormBoundaryo5Y+YTyft0u0Ar
>I like the Norton SG and 3X wheels for sharpening the powder-metal tools (Thompson, ASP, OneWay), and for M2 HSS too. My choice is a 46 grit SG, and a 120 grit 3X. On a high speed (3450 rpm) grinder. With a OneWay wheel-balancing system to minimize vibration.
