Foredom Tool
Jim Tusant
>Can anyone provide comments on the Foredom flexable shaft carver. I have not used or handled one. Are they worth the investment for carving on bowls? I have been using the Automach, Dremel and hand tools.
Foredom Tool
Jim Tusant
Re:I have gotten great use out of....
Jamie Donaldson
>...my Foredom for many years, and often with the Wicheer power carving handpiece. Beats a Dremel with more power and larger attachments, and the variable speed controllers are a must have.
Bruce McElhaney, Spring Lake, Michigan
>The Foredom is well suited for larger heavy carving. It has a lot of power transferred through its flexible shaft. The variety of bits and accessories for it seem endless. I used to use one for carving duck decoys and such. But for finer control and more delicate and precise carving, I much prefer a Dremel type tool. The ultra high speed electronic carving units are even better yet, but the good ones are pricey.
Jim Tusant
>Thanks Jamie, I was concerned about the cable getting in the way of the work. In a way, I thought it might limit the use of the tool. You may be right about the power because the Dremel is not a AA fuel dragster for sure.
Re: Foredom Tool *LINK*
Don Evans
>Here is a machine that in my opinion is much better than a Foredom.
It is called a Mastercarver Pro, it can be both hung up like a foredom but I prefer the bench mount much better.
One problem with heavier motor unit is that they can start to swing when hung up, the bench mount cures that problem.
This unit has several hand pieces, reciprocating, one that is same diameter as the dremel, one that is larger and has chuck (like a drill) that takes every size bur up to 1/4" diameter. You can also get a 90 degree. The 90 is only one I don't have.
This unit is also 1/3 hp.
If you have been using a Dremel flex, you'll be very surprised at how much more flexible this units shaft is.
Good price also.
http://www.woodcarverssupply.com/store/
No affiliation, just satisfied customer.
Re: Foredom Tool
>Jim I've very happy with the foredom. I use the Dremel as well. I find the Foredom stronger than the Dremel but the shaft can be a problem sometimes for delicate work. The Foredom is much better for taking bigger bites. If you need to remove a lot of wood I would suggest something like the Arborec and an angle grinder.
The Foredom will also take a reciprocating handpiece which makes it good for some cuts that rotary tools can't do. Another nice thing is you can get handpieces that will take up to 1/4" shanks. That allows you to use cutters not available to the Dremel.
The one downside is you can break the flex shafts fairly easily if you get a catch with a larger tool or wrap the cutter up in your clothing. Not that I've ever done this of course. By an extra shaft and keep it on hand. I will go a few years without damaging one and then when you need it the most trying to finish an overdue project, bam, you have a bent twisted or brocken inner shaft. It only takes a minute or so to change it and they are about $17 or so.
Re: Foredom Tool
Jim Tusant
>Don, thanks for the tip. I just ordered a catalog from them and will spend more time on their website checking out the unit. The pricing is about the same as the SR Foredom 5200 kit but with a larger motor size. Looks like an interesting choice.
Re: Foredom Tool
Jim Tusant
>John, I feel like a pioneer that went westward without a covered wagon. I guess I am going to invest in the flex-shaft tool after all. The Dremel is slow work for carving on the bowls. Don sure presented a good looking alternative to the Foredom. Your suggestion for obtaining an extra shaft could be a lifesaver. Thanks for the response. When you get time, you should drive down to Memphis for our club (Midsouth Woodturners Guild) meeting. Good donuts and coffee!!! Someone in north Arkansas told me the other day that they thought Memphis was the garden city. I admit I was somewhat surprised until he finished by saying that when you leave home he heard you had to guard everything or they would steal it. Oh well, it sounded good for a moment.
Re: Foredom Tool
John Jordan
>I have a BRAND NEW Foredom, the table model, variable speed with rotary AND reciprocating handpiece. I would sell it for whatever great discounted price I got it for at AAW a couple of weeks ago. I will have to look to see the actual model number. It's been used maybe 10 minutes.
Nothing wrong with it, just not what I want.
John
charlie belden
>Get the "full wave rectified" foot pedal. Unlike the less expensive carbon pile sewing machine type speed control pedal, you get almost full torque starting at very low rpms, whereas the carbon pile needs higher rpms before you get any torque you can use.
I've had two foredoms, both with the full wave rectified foot pedal for 25+ years. Wore out the bearings in one handpiece eventually, and killed an angled dental type handpiece, but the motor and flex shaft seem bullet proof.
You can probably get a less expensive flex shaft unit - but you'll buy two or three of them for one good Foredom. Don't know if they still have the very high speed handpiece which got up in the 30-40K range.
I got a non-foredom reciprocating "carving" handpiece. Works - once you get used to it.
Re: Foredom Tool
Don Evans
>Couple of additional comments:
There are two types of flex shafts, one is called a "square drive" the other is called a "snap ring".
Foredom uses both types depending on the model machine you buy, you do NOT want a square drive. If you are rushing and asking the square drive to hog it you will more than likely strip out the inner shaft.
Also maintenance on the shaft is all important. Purchase the grease for the shaft when you get the machine and follow instructions to clean and lub it and it should last many years. Do NOT use a different type of grease. Aligh the motor with your work so the shaft stays mostly straight, just cause it can be bent doesn't mean you should turn it 90 degrees to the work, this causes excessive wear due to internal friction.
Dremels flex is a square drive fyi.
Handpieces are not interchangeable between these. The unit I recommend doesn't sell a square drive.
Second comment:
Foot pedal variable speed set up. Using a foot pedal and carving is like hopping up and down while rubbing your stomach and patting your head with the other hand. It is clumsy and just NOT needed. When doing a job you do not have any reason to change speeds while using a particular bur, you set it to one speed (or try too with your foot) and it stays at that speed. Concentrating on your carving and your foot at same time just doesn't work as well as the unit I showed you.
Don
Re: Foredom Tool
Jim Tusant
>John, check out all the details for me and let me know. Was it a kit or single unit and model #. What controller (foot/table) does it have and so forth. Thanks
Re: Foredom Tool
Jim Tusant
>Good stuff Don. Experience pays for sure.
Re: Foredom Tool
>Jim I done a demo down there. Stayed with the Great Don Wilcut. We had a good time. I think any major city would now be called the Garden city based on your description. That's why Bill G. and I travel armed.
I have looked at the master carver and it looks like an excellent machine. I now have 2 flex shaft machines. The 3rd one which was a no name finally died. I can't find shafts for it. I actually repaired the shaft 3 times until I just couldn't figure out a way to fix it.
My other machine is an older Weecher. It is not as smooth or as powerful as my Foredom but that's not a condemnation of the Weecher. The models are simply different.
You can definitely take off more wood with the foredom than the dremel. I use a lot of sanding drums as well for cleanup and having they are hard to find in the 3/32 shaft sizes. You can easily get them in 1/4" from thesandingglove.com
Have you thought about air tools or electric die grinders. They take off wood even faster. Air tools require a large air compressor which can be a setback. Electric die grinders are kind of large for a hand tool but will really hog wood and are pretty inexpensive.
Re: Foredom Tool
Jim Tusant
>John, I have a two-stage air compressor and I have tried the air tools. I am not fond of them. I think with all the positive opinions I am going to try the flex shaft tool. Thanks for all your help. Don't be a stranger and visit us again. Like you and Bill G., I feel naked without some comfort around town and home. It is a shame that our country has gotten to this point but that is a whole different story. Come see us soon.
kerry brown
>They are great if you get the reversible direction motor. It can be set so the sawdust heads away from you instead of getting into your face.
Slow for really precise detail carving, for that get a high speed air driven turbine to use with a compressor. Harbor Freight has an micro die grinder that will do. Be sure you match the maximum bit speed to the speed of the grinder or else your bits can shatter and hurt you.
micro die grinder
Re: Foredom Tool
>I bought that one. Mine is totally useless. It doesn't have any power, makes lots of noise and eats up air. I know there are better ones on the market but unless mine is faulty it was a waste of money.
Re: Foredom Tool
Jim Tusant
>Don, thanks for the suggestion of the Mastercarver Pro Bench model. After quite a bit of research, I ordered one today. You are right about the value of what you get in the set. I'll give this baby a good workout as soon as it arrives. Thanks for the tip. The people at WCS were extremely helpful and went out of their way to assist with some pretty stupid questions from me.
