Peppermill time
Steve Kubien
>Been busy. Let me know what you think.
Rattle-can lacquer finish, approx 10". Colourwood from Artistic Wood and Tool Supply.
Peppermill time
Steve Kubien
Re:Much improved images, but you're .....
Jamie Donaldson
>... not using a Phrugal Photo enclosure to advantage with the flash as a light source. Try some diffused lighting to soften the shadows, and the mills are too close to the background.
Re: Peppermill time
joaz
>Hey Steve, I went to Artistic Wood supply and could only find the color wood in 5" tall pieces. Do you have to order longer ones?
As far as your design goes. I tend to make mine thin about half way up ala Rude Osolinik. How do you like turning this stuff?
thanks...joaz
Re: Peppermill time
Steve Kubien
>Peter's site stock is in a constant state of flux and his website is, perhaps, not as up-to-date as it could be (also not the easiest to find what you are looking for). Luckily for me, he's just a few minutes down the road on a Saturday or Sunday.
I would suggest emailing him through the site. Tell him you are after the dyed, colourwood, birch and tell him the size you need. I believe he prices it by the inch and you can get it up to around 48" long (aka, A Honkin' Big Mill!)
As for how it turns... Well, it's not like regular, solid wood because the shavings tend to be very short but that's because of the thickness of the veneers. What you end up with is a pile of shavings that look like it was made with 20 grit paper. It reacts well to sharp tools (I have better luck with a spindle gouge than a skew but YMMV), sands easily and sucks up a finish big-time (!) unless you use a sanding sealer.
I think that covers it. Good luck.
Steve Kubien
Re: Peppermill time
joaz
>Thanks Steve, I will give him a shout.
