"Fitchburg Machine Works" lathe ??
Chuck Engstrom
>Does anyone here have any knowledge of Fitchburg Machine Works lathes? A fellow around here seems to have one for sale and says it will handle 14" diameter by 40" length. Old 220-volt motor, several tool rests, faceplates, etc.
I might have to go take a look. Any info/suggestions/caveats ?
Thanks--
Chuck Engstrom
Chestertown MD
Re: "Fitchburg Machine Works" lathe ??
Rob Wallace
Re: "Fitchburg Machine Works" lathe ?? *LINK*
Rob Wallace
>Chuck:
There are three images of a Fitchburg Machine Works lathe at the link below. Over the past few years, I've seen maybe three or four of them listed for sale on eBay I don't know much about them, but my usual first destination for such information is the Old Woodworking Machines Web site.
Good Luck on researching the information about the Fitchburg, Massachusetts company that apparently had changed names at least once in its history.
Cheers,
Rob Wallace
Old Woodworking Machines Web Site - Fitchburg
Chuck Engstrom
>Thanks, Rob. I did see those after a google search; the lathes shown are different from the one up for sale here.
I also found another site with a chronology of Fitchburg indicating that they stopped doing business as "Fitchburg Machine Works" in 1924.
Best--
Chuck
Question?
Ron Bauman
>In the first pic from OWWM the lathe shown has a lead screw. Would this be a dual purpose lathe, ie., metal and wood. The box of gears would lead me to believe that it could be set up for thread turning. Or would it be metal turning only?
Rob Wallace
Re: Question?
Rob Wallace
>Ron:
I assumed the first image on the OWWM web site to be that of a metalworking lathe; I don't know many wood lathes that have a sliding carriage that is typically driven by an Acme threaded screw.....
Seems there's not a lot of information on these beasts, at least on the Web.
Rob
joaz
>I have been turning on my old Fitch for years. I had to install pillow blocks on the spindle be cause of endplay in the babbitt bearings. Also had to have a tool rest made. The metal turning carrige was removed by the it came to me. I was told it made munition in the civil war. Mine is stamped 1865.
I was offered a lot of money for it by a collector until he found out the carrage was missing.
At one time I had installed a pedal on a hinge to raise and lower the motor in order to change the speed by slipping the belt. I have since installed a 220 3phase motor with speed contol remote.
The thing weighs around 800lbs.
It has a 13in throw and must be about 3feet long. The tail stock is adjustable to make tapers. I assume for gun stock. If you go to may web site you will find a picture of it on the front page.
I love the old horse but do most of my turning these days on the Powermatic.
If you want I think I still have info. from the collecter about this lathe that I could fax or mail to you. And could send you pics via email. Let me know. Maybe we could start a Fitchburg lathe club.
Joaz www.maine-web.com/woodturning
