Boring a lamp Questions
>I want to turn a lamp out of a solid blank. Actually probably four lamps. The last time I drilled one, was many years ago and I drilled out the side after I had finished turning it. Since then I have glued up the blanks with a hole left up the middle.
I do not have a lamp auger. It I had one, I would need the centers that go with it that are hollow, allowing the auger to pass through them, right? What does this cost? Times are tight and I don't want to spend the money.
I do have a long drill bit that is more pointed than standard twist drills. I also have a floor model drill press. I am thinking of drilling the blanks before I turn them, gluing a plug into the hole and then chucking them on the center of the plugs. After they are turned I could drill though the plugs.
Does this sound like a plan? Got any better ideas? Two of the blanks are pine and two are walnut. They will be 15 to 18" long and about 3 1/2" square.
Re: Boring a lamp Questions
Chuck Engstrom
>Hi Barry -- I have done a bunch of chandelier spindles, which amount to pretty much the same thing as lamps -- a wooden shape with a hole all the way through for the wire.
My general practice was to drill all the way through the rough blank first. We were typically drilling for eventual use of all-thread tubing which needs a hole just over 1/2", so I started with a standard 1/2" bullet drill firmly fixed in a chuck in the tailstock with the rough blank mounted in a Stronghold on the headstock -- grip hard! I'd go as far as I could with that and then go to longer and longer drills till I was all the way through. (What you say you have sounds like what I think of as a bell hanger's drill -- a pointy end and usually a small hole through the drill not far back from the tip, where you can tie a piece of string or wire once the drill has passed through a wall and then pull the string back through.)
Once I had a hole all the way through, I mounted between centers. At the headstock end I used a homemade brass gizmo which amounts to a 1/2" shank with a "head" on one end which is A) small enough in diameter to fit inside the teeth of a 1-1/4" Steb center, B) drilled out slightly at the center to accept the sharp spring-loaded point of the Steb, and C) shallow enough to allow the Steb's teeth to dig in when its center is pushed back. (It would be much easier here to show you a photo but all my stuff is packed for an upcoming move.) This gizmo goes into the hole in the end, and it does need to fit snugly in the bore so that there's no slopping around. In the tailstock end is a Oneway live center, whose end taper will fit into 1/2" with a little care. Be sure you have given yourself enough length
This lets you turn on the true center of your bore, which has usually wandered substantially from the original center at the far end of the hole you drilled. Yes, you can put a plug in your drilled hole and go for the center of that, but one rarely gets a true center that way since the grain always seems to push the point of your spur center to one side or the other.
I hope this is some help. It is not the simplest possible approach but if you are going to do more lamps over time, it's worth making the gizmo, and I now have them in both 1/2" bore/1-1/4 Steb and 3/8" bore/7/8 Steb. You can make them on your wood lathe with a little patience as brass is pretty easy to work (I used cast-off propellor shafts, easy to come by in these parts). Remember that for machining brass you are more scraping than cutting.
Good luck with it!
Best--
Chuck Engstrom
Chestertown MD
>I do have a lamp auger and the centers but before that I did similar to what Chuck described. For shorter lamps, about 16" or so, here's the procedure I use. I drill one end with a regular short drill bit so I get a hole about 4 or 5" deep.
Then clamp a piece of wood on the drill press and drill the same size hole. Put a dowel that size in the hole. Now place the end of the lamp you just drilled on this dowel. Drill the other end.
Now I put the lamp in my vise and use a hand drill with longer bits and drill to the center. If your lucky the meet. Sometimes they are off a little but I use a 3/8" drill and a lamp cord will fit through even if you can't get a lamp rod through it.
I epoxy short pieces of lamp rod in each end to take the lamp hardware. To get the cord through tie a piece of string on the end of the lamp cord. Then use a shop vac to suck the string through the hole and pull the lamp cord through.
To turn the lamp I have a Nova tail center. I turn a short #2 morse taper on one end and a 3/8" tenon on the other. This fits in the lamp hole (usually the top) For the bottom I just use a drive center and eyeball the center. I have used a 60 degree point when I could turn a short tenon on the other end for a chuck to hole. That way you don't have to put much pressure on the tailcenter to hold it. I usually turn a seperate base and the tenon can go into a mortise on the base for alignment.
ben d.
>I would have a couple suggestions that have worked for me.
I would drill the hole through and if you have glued it up and left some kind of a hole in the center you can drill it with a hand drill and drill from both ends and it won't be as far off.
Next after the hole is there either chuck up a piece of dowel the size of the hole or mount on a face plate some piece of tough wood on the end grain and turn you a dowel then put your blank in the lathe and use a pointed live center push it up and most likely you can turn it with this set up or on one end turn the blank round and then chuck it up with a 4 jaw chuck and and you can turn it that way without any problem. Leave enough length for it to be chucked up.
I would say your blank will not be too large to do this with.
ben d.
