Finishing with paint over dye???
keith zimmerman, Normal, IL
>I am getting ready to do some experimentation with a spray paint finish. The finish I want to try is one that has captivated me since my college days. At the symposium, I saw Molly Winton and Andi Wolfe's demos and saw techniques that might help me in that quest.
My quandary; I have the first hollow form ready to apply the paint, but it has been dyed with leather dye. I have a feeling I should seal the dye some way, but don't have any idea what would work best. Any suggestions would be greatly appreciated.
Thanks in advance.
keithz
Re: Finishing with paint over dye???
Ted Evans
>Have not used it myself, however, many use shellac for a sealer. It seems to be compatible with many finishes.
Re: Finishing with paint over dye??? *LINK*
Bill Clark
>I would try "Zinsser Bulls Eye Seal Coat". The big box stores have it. It's a one pound de-waxed shellac that you can top coat with almost any finish. I seal most of my turning with it prior to a top coat of "Minwax Wipe On Poly". It drys fast and is a great sealer.
See this link:
Zinsser Seal Coat
>If the shoe dye is dry the paint should go right over it. Try rubbing it off with a rag. If you don't get any or only a little rubb off then it should take the paint. The only time you could have a problem would be if you are brushing and needed to go back and forth when spreading the paint. spray paint should work fine.
If in doubt, use a thin layer of shellac. That's my standby. I try to run tests on scrap pieces so there aren't any surprises but I do get laze sometimes. In those cases a quick spray with shellac solves the problem.
Russ Fairfield
>Spray can paints are funny in that they don't use the normal solvents and thinners that we are used to, and there is no way to predict what they will do. Always test first, before coating the entire piece. You may or may not be able to coat over it, and you may or may not be able to use shellac as a barrier between them if they are incompatible.
There are differences in brands of the spray paints. For what its worth, I have always had better luck with Rustoleum sticking to other finishes and surfaces than with Krylon, and with primer and BBQ paint than with an enamel. YMMV
