busy weekend
busy weekend
busy weekend
>Yesterday I hauled all my old wood to the dump. Man it's hard to let go of that stuff, but every once in a while you have to head John Jordan's words, Life's to short to turn (you know what kind) of wood.
Then I played with the Vega Duplicator that Randy so kindly sent me to try out. I'll have a complete report on that at a later date. It works better than the duplicator I used many years ago and did the job I intended to do. I plan to run some more tests and talk with Randy about my observations before writing something up. here is what I did with it so far. These are finials for a friend.
The white one was his. I made a pattern that would allow me to turn 2 at once. You can't do a facing cut with a duplicator without changing the cutter (which is simple to do but you might loose the reference point for the first cutter, more on that later) You can rig the duplicator up so you can still use your tool rest but I simply took the spindle off and used my other lathe to sand and do the parting cuts for the top and bottom.
Re: busy weekend
McNaughton coring system
>I cut up some wood last night so I could give this tool a try. I have lots of wood right now and I loose a lot to rot because I can't rough enough bowls. I thought the coring system might help this.
My first try was a success, thanks to all of you who made suggestions. I got 2 catches, and I'm still not sure why. I successfully cored it to about 1" thick except for the bottom which was about 1 1/2.
Re: busy weekend
learning curve got me
>The second one went much smoother. No catches. cleaning out the waste each cut was smooth and it felt like i had control of the tool. That was until I noticed the outer bowl was not turning with the inner one. oops. I thought I was arcing the tool quite nicely. I find it very difficult to know where the cutting tip is. I know it's in line with the straight shaft but judging how deep is very hard for me so far.
Oh well I did get one good bowl out of it. I have 2 more thicker blanks to work on this afternoon. Maybe I'll have more success. I plan to add a lazar to it but right now I just don't have the time and my metal lathe/mill is down. When the parts come in for it I will get excited about building the lazar.
Re: busy weekend
Yard line markers
>I know what we need for this tool. You know how they show the First down lines on the football field during a game, or how they show where the tennis ball is in our out. We need a video camera that is mounted above the lathe that has a computer generated image of the bar inside the bowl. Then you could just watch the monitor and adjust cut cutter.
Re: busy weekend
Rob Wallace
Re: Yard line markers
Rob Wallace
>John:
This is what the laser is supposed to do when mounted on the cutting tool - shows you where the cutter tip is. I've had good luck with my McNaughton coring system, and have only made one funnel so far (very similar to the one you have shown). I haven't added a laser guide to mine yet, but may do so then I get some time.
I've thought about similar ways to control the tool path as I'm coring....It would be even easier to set up the overhead image of the blank and then specify the cutting path cutting path on the screen for a CNC tool positioner to take over and core the bowl for you. Would that still be considered woodturning?
Rob
Re: busy weekend
Re: Check this out
Eddie Pacheco: Now in Antioch, Ca.
>Am I the only one that cringed when Bill daintily, and calmly plucks the shavings from the coring tool, between the pivot rest and spinning blank?
Re: busy weekend
Re: learning curve got me
Don wilcut
>Nice thick lamp shade.
Re: busy weekend
Here's my stash- took longer than Bill
>I think part of my problem today was doing bowls that were deep. I had shavings clog up the cut and had to remove the tool about 4 or 5 times at least to get the shavings out. The small ones went somewhat like Bill. Of course if we stood side by side it would look like Popeye and Bluto.
I mandaged to get 9 good ones and 1 funnel out of a log about 14" by 28 inches. This log had really thick bark. I only had 2 catches but did have 2 or 3 instances where I almost couldn't get the tool back out after it clogged with shavings.
I also managed to jam the bandsaw blade in one of them. I had to drive chisels and cold chisels into the kerf until I broke the wood to get the blade free. I haven't had that happen in a long time.
Re: busy weekend
Steven Antonucci
Another YouTube video
steve antonucci
>shows a guy using air or water (can't remember which) to keep the cut clear. As you have found out, when it works, it is sweet. When it doesn't, bad things happen quickly.
Keep at it. By the time you wear the knives out, you should be an expert.
Steve
Re: busy weekend
Re: busy weekend
Dick Coers
>Did you mount the duplicator on the back of the lathe or the front? I like to use mine on the back (flip the cutter over) and keep the tool rest still on the lathe. That lets me sharpen up some details if I want to.
Re: busy weekend
Re: Check this out
robo hippy
>Am I mistaken, or is Bill packing a pistol? Target practice on the core as it rolls away?
When I have to get the shavings off the tip, I never stop the lathe. No need, fingers are pointed down, and you are away from the wood.
robo hippy
Re: busy weekend
Re: Check this out
Bill Grumbine - Kutztown PA
>It's my water pistol, to spray the knife as it enters the blank! ;-) Seriously though, Bill is wearing his "house gun", an Airlite S&W .357 magnum 7 shot revolver. Even with 158 gr wadcutters, it is so light I don't even think about it being there. When I am out in the field, the first three chambers are filled with snake shot for any critters that might emerge from the log pile bent on harming the human. Rabid animals are not unheard of around here. It also serves well for two legged varmints that may show up from time to time unannounced. And being a political activist, it allows me to exercise my 2A rights while working in my humble abode.
Re: busy weekend
Re: Check this out
>Eddie, the first pluck is above the tool, when it can only move down. The second pluck occurs when the tool is completely disengaged from the wood. Foreshortening makes it look like my fingers are in danger, but they never get close to getting in between the tool post and the wood.
Re: busy weekend
Re: Check this out
>Eddie I caught myself doing the same thing. The shavings tend to pile up around the opening and cutting tip when you pull it out. Brushing them away from the top side like that seems perfectly safe when you do it. I keep my fingers above the cutter and away from the bowl.
Re: busy weekend
Re: busy weekend
>Dick I mounted it on the front for this operation. I'm going to set up another project and use it on the back side. This time around I simply took the spindle off the lathe and put it on my other lathe to do the parting cuts and to sand. If I only had one lathe I would definitely put it on the back side. You would have to readjust the height so the cutter would be at or above center, rather than at or below center.
Re: busy weekend
Re: Check this out
Grant Wilkinson
>Good video, Bill, but it doesn't seem like "you" without some witty commentary.
