Wheelchair Lathe Setup Ideas?
Jerry Hall
>I volunteered as a part of our local club's demonstration at the upcoming county fair (Nevada County California) to set up a "hands on" opportunity for the disabled, presumably wheel chair bound. As the time draws near I need to prepare!
My plan is to use a 10" variable speed jet mini, to avoid belt changes. I was going to build a lathe stand that would allow a wheel chair to roll into an opening, and have the axis of the lathe at elbow height for a seated turner.
My thought is that with the top of the stand at 24", the lathe axis would be close to 30". Clear as mud I suppose....I would appreciate any thoughts you may have on this, and needs I should consider in developing a setup. I wouldn't want to ask the turner to change chairs for a relatively short experience, and for safety as well.
It could be as simple as clamping the lathe to a 24" high carpenters sawhorse I suppose, if it is sturdy. Since the turner can't easily move, maybe the lathe should be able to pivot on the stand surface. Or if it was on the sawhorse it could be moved a bit for different cutting angles?
Jerry
