MOHICAN Bowl Help
MOHICAN Bowl Help
MOHICAN Bowl Help
Carl Barton
>Many of you looked at my new designed bow the other day and I was hoping you might be able to give me some more advise/help on the new one I am currently making.
If you recall the design, in the center it looks like a bullseye. This is made by using a combination of forstner and plug cutting bits. In the case of this desgin I start out with a 3/4in, plug the hole with 3/4 in plug, cut out a 5/8in hole, plug with a 5/8in plug, cut this out with a 1/2in hole,plug with a 1/2in plug, then a 3/8in hole then plug with a 3/8in plug.
The issue I am having is one would think if everything is centered when you cut the first hole then all the other holes and plugs would line up to cut the other holes and fill them with the plugs. But they are not. A number of the segments are not centered when I start to cut the next hole.
Before I started the first hole, I ensured all my segments were the same size. Once I had the first segment centered on the bit to cut the first hole, I locked everything on the drill press down good and tight, the table, the fence and the block the the left of the segment that I press it against when I drill the hole. When I went to cut the next hole in the process a number of the segments holes would have been way off center while others were dead on. I had to readjust the fence and my left block for at least half of the segments.
I know I am asking allot, but hopfully someone can understand my jiberish and give me an idea why all the segments are not lining up when I go to do this.
Carl
Re: MOHICAN Bowl Help
>I've had weird problems like that before. They don't make sense. Something is obviously slipping. Check the drill press table. You may need to make a 2 point positioning block for the table to hold the segmented pieces, one on the side and one on one end.
Other than than I don't know what to tell you. Are you sure they were off center? Sometimes the grain of the wood will make things look off when they aren't.
Curly Smith
>I would guess two things happened:
- you didn't actually get the first hole centered, you got it very close but not centered
- you didn't keep the top & left sides of the pieces consistent
If you didn't actually get the hole centered it wouldn't have mattered if you'd always oriented the pieces in the same direction because all future holes would be in the same place. However, if you flip the pieces then you'll see 2x the error so it'd be pretty obvious.
The same would hold true if all of the pieces weren't precisely the same size (I assume that you're not sanding until after you've done the inlay?) and you flipped the orientation, which is really the same as above since the hole won't have been centered...
Carl Barton
>MMMMMM lost of intresting points. I have only one side of the pieces blocked, the left side. But while I am drilling I hold the piece against both fence and the left side.
I have all the pieces marked so they will always be pressed against the fence in the same way.
The only thing I do that you mentioned is to sand the face of the pieces so the plug that sticks out above the segment is flush before I drill the next hole. Would this make such a big difference????
I have 12 segments, 6 of them are almost dead on when I drill and plug them, but the other 6 all all over the place when I go to drill them. I had to do each one of these by hand they were so off. What I did was measured and centered each plug after I put it in, then drill each hole by holding the segment by hand and going really slow. It did a much better job than holding the segment against the fence.
Carl
Carl Barton
>John,
As I put each plug into the holes I ensured the grain orintation matched the rest of the segment.
I also added some other information to the other gentelman's post. It is just so strange. I have done this design three times now and each time I have had this issue. It has to be something I am doing but I can not put my finger on it. I was able to center the plugs much better when I drilled and held each piece by hand.
Carl
Curly Smith
>The sanding would make a difference if you shortened the length.
Another thought... Could you make a simple jig with an angled stop block (same angle as your piece but flipped over) glued in a groove (so the piece can't slip under the stop block) and a perpendicular fence? The angled stop block would give a much better register than a square one, which relies simply on the edge, making it much easier to hold while drilling, and you wouldn't have to fiddle with two alignments.
Using Forstner bits?
Jorge Castaneda~Downeast Maine
>Carl,
If you are using Fortsner bit, they may be slipping. I only use Convalco Forstner bits, yes they cost a little more but when they are sharp they can cut very precise, no slippage. So called Forstner bits with saw teeth, are not in the same league and they can wander.
Re: Using Forstner bits?
Carl Barton
>I never heard of these types of bits. I will have to look around for them. Thank you
Carl Barton
>Nope I did not sand the sides or ends, only the face of the segment.
That is a great idea. I do not know why I did not think of this before. I made something like this before for a southwest cutting board that had multiple pieces. This might do the trick, becasue trying to do it by hand does get a bit tedious, and hard to keep lined up. Thanks for the idea.
Carl
Texian
>Carl, Sounds like you are handholding the pieces in the jig for drilling. Suggest you verify no chips in the way each time and clamp the piece in the jig each time. Assume you build the pattern before cutting the miter angles on the ends. Suppose either way could be made to work.
Carl Barton
>I am holding each piece by hand now, it seems to center the plug much closer than what I was doing before. After each item has been drilled I vacum the entire area before I proceed with the next piece.
Curly Smith
>Another thing that you could try is drilling a shallow pilot hole with a brad point bit that's slightly smaller that the "spur" on the forstner bit. Brad points are less likely to wander when plunging into the wood. It'd be 12 more holes per step but it might tell you if the problem arises from the forstner bits.
