Grizzley Lathe Chuck
Joe Meirhaeghe
>So who here has a Grizzley Chuck & whats your thoughts on it? I'm undecided as to buy a Vicmarc VM 1oo or the Grizzley. Is the Vicmarc really worth more than twice the price?
Thanks Joe
Re: Grizzley Lathe Chuck
Re: Grizzley Lathe Chuck *LINK*
Fred Holder
>The Vicmarc Chuck may be worth three times the price of the Grizzley. I believe the Grizzley is a copy of the Vicmarc chuck, but not nearly as well done. Victor of Vicmarc says that the Chinese copied his chuck and even the user manual, but didn't do as good as the original. I own two of the Vicmarc Chucks and they are worth every penny I paid for them.
More Woodturning Website
Gary in Zirconia, NC
>I agree with Fred. I have the Grizzly and a Vicmarc 120. The Grizzly is not nearly as well made. I have replaced the jaw screws after they striped also. The price only hurts once, you will enjoy a good chuck forever.
>I own both. I've been using them interchangeably for the last 2 years. The Grizzly is a decent chuck but not nearly as nice as the vicmarc. The Vicmarc resists rust better, chucks up wood more accurately and isn't as sloppy in its inner workings. If you are definitely on a budget I would recommend the Griz. If you aren't the Vicmarc is definitely better. I've also heard of some problems with the Griz fitting lathes. It has happened with the Vicmarc but a whole lot more seldom.
cliff
>i have a griz 3.5" chuck for over a yeatr now no issues , good chuck for the $$$$$
Texian
>I have two of the Griz chucks and believe they are good value for the money. They grip the wood securely and cause it to rotate when the lathe is turned on. That pretty much takes care of it for me. Just a matter of dollars and priorities. Would rather have two good chucks than one great(?) one.
I vote for the Vicmarc
Eddie Pacheco; Now in Antioch, Ca.
>I bought my Vicmarc chuck when I was just learning to turn and had a tight budget. That sucker has worked well for me and has looked away at some of my turning sins and has heald steadfast on some of my chucking blunders. Most of the other accessory pieces to it are all Vicmarc.
Having said that, I did order s set of Jaws from Griz. because the price was very right. Sadly, on these jaws the fit was perfect onto my Vicmarc. Also, I found that the deburring of the edges was better right out of the box. They haven't rusted and still look good.
I won't buy a copycat Vicmarc chuck, but I will sway on the Griz. jaws.
Rob Wallace
Rob Wallace
>....what John Lucas said.....same as my experience here....
I own two VM-100's, a VM-120, and one of the Grizzly knock-offs of the VM-100.
I tend to use the Grizzly only in non-critical applications, but it does perform fairly well, just not as smoothly as a Vicmarc.
One warning about the Grizzly chuck. Some of the machining (particularly on the back plate with the indexing holes) was not well-finished in the chuck I got (they have to cut costs somewhere). The back edge was quite sharp on its outer edge, enough to cause a potentially serious injury, and I did manage to get a cut on my left hand from the back edge of the chuck. Just a word of caution that once you receive the chuck, give it a careful once-over to be sure there are no sharp edges or metal spurs that could do damage to you or your lathe spindle. I may get another Grizzly chuck for use on my new Jet 1220 lathe. Not a ringing endorsement, but still fairly good value for the money, as has been said.
Rob Wallace
Bill Clark
>Joe, I had one and returned it. As others have said they are not well made. Mine did not run true and the "T" handled Allen wrench that came with it was so soft I had to continually grind the tip back because it kept rounding over. Do yourself a favor, don't buy cheap tools. Buy the Vic and it will serve you forever.
Steve Harder
>I don't own a Vicmarc so I can't compare -- but Grizzly has served me very well for several years. If you send me an email I can send you a very detailed guide to tuning up a Grizzly - a posting by www.theturnersshop.com.
BQ in VT
>I agree with the people who say spend the money and get the best you can afford. It does only hurt once and is cheaper in the long run if you don't have to buy a new chuck to replace the cheaper one you bought in the first place. That being said, I have not used either, I am a Nova Chuck(ok, stop laughing everyone)user. I have been using them for a long time when there were not as many choices as there are today. They were the more expensive choice at the time and I have been using the same chuck for almost 15 years.
