Have a question? Ask Woody!
Wiring Problem Driving Me Nuts!
charlie belden
>The wiring of the Biological Imperative piece is driving me CRAZY. The attached image is basically the wiring for the three electrical parts - the battery pack, the LED lit push button power switch and the electric motor. The first two parts go inside the Ovum component while the motor goes in the Sperm component. When the power button turns the power to the motor on and off, the LED in the switch is turned on when power is ON. The important part of the wiring is making sure that the motor turns in the correct direction to cause the wheel attached to the motor to drive the Sperm component FOREWARD - the tethered power cord going into it being the FRONT.
So I wire things up and test the circuit. Motor turns, wheels turn in the correct direction. Assemble everything - pushing the battery pack and wiring into the cavity in the Ovum cut out for it. Push on the power button - and the wheels on the Sperm component turn - in the WRONG DIRECTION.
Remove the drive wheels and drive shaft on the Sperm component, reverse the wires on the motor, temporarily reinstall the drive shaft and wheels to test that the direction of their rotation is now correct. Wheels rotate in the correct direction.I Turn on the "Correctly" wired motoragain - and the wheels are now rotating in the WRONG direction.
Repeat the above procedure - switching the wires on the motor, test and everything is now right - wheels rotating to move the Sperm component foreward. Remove the drive shaft and wheels, install the motor - with the wiring unchanged - back in the sperm component, reinstall the drive shaft and wheel. Push the power button, LED goes on, wheels spinning in the wrong direction.
So I'm thinking the push button power switch has a polarity reverser - push once to turn on to apply plus side of power to A, push again to turn off, push again to apply plus side of power to B.
NOPE!
HELP!
What's flipping the polarity to the motor!?????
Re: Wiring Problem Driving Me Nuts!
Never Mind. Another THINKO (mental Typo
charlie belden
>Problem was NOT the wiring - but the interpretation of data. Was looking at the wheel UPSIDE DOWN. THAT reverses the apparent direction of rotation. see illustration below.
Information, without context, can lead to incorrect (read WRONG) conclusions.
My bad.
Re: Never Mind. Another THINKO (mental Typo
Peter Rand
>Charlie - I was thinking the sperm was carrying an X chromosome.
