Biological Imperative Vid up on YouTube *LINK*
charlie belden
>I've got to get a digital video camera - and use the other two 500 watt fotoflood lights - with umbrella reflectors - I got last week. Apologies for the video quality.
The wiring STILL isn't right. The push button Power Switch is supposed to light red when the power is on. Took five tries just to get the motor that drives everything turning in the right direction. Looks so simple in a wiring diagram. Then you start connecting the seven wires coming out of the opening in the bottom of the Ovum into which the wiring and battery pack are hidden - and what you THINK you did and what you ACTUALLY did diverge - rapidly.
The Ovum is a plant arranger's foam ball, with two coats of white jesso the painted pearlescent white with GOLD Thick Get medium applied with a hypodermic style plastic glue applicator and pearlescented again. Had to drill holes in the inside of the foam ball and fill with lead birdshot to give it enough weight so it'd stay still while the Sperm Component wound around it.
Eccentric wheels will probably be replaced with clear plastic to be less conspicuous. Will break out the Light Box - and the other two floor lights for the still photos of this piece - then update the web pages on it.
Interesting project.
First vid of Biological Imperative kinetic piece
Re: Biological Imperative Vid up on YouTube *LINK*
That's just too funny. Thanks.
Steven Antonucci
You are a strange bird, Mr. Belden :-)
steve antonucci
>I half expected an army of them with lasers killing each other until only one was left...
Good show...
S
Cute - maybe you should take it to a Bio class
>or a Sex-ed class.
Re: Cute - maybe you should take it to a Bio class
charlie belden
>That's sort of what I had in mind. Daughter-In-Law is pregnant with her third - already with a 6 year old boy and 4 year old girl asking questions. And several of my neighborhood adoptees - this batch mainly girls - are in that Not A Child, Not A Woman period with all kinds of confusing changes going on, lots of questions and other kids to turn to for info. These "kids" are entering a period of their lives where the Biological Imperative has significant affects on their social life. Knowledge is power and if they understand what the game is about, hopefully they'll make better decisions selecting friend and boy or girl friends.
If you want to convey info to teens, first you have to get their attention. And humor is one of the better ways to get their attention and interest. Hopefully, this piece will be taken as cute and funny - but the underlying intent is very serious.
Bob Macgregor
>I wonder if using a monofilament (fishing line) tether would help reduce the distraction (and biological incorrectness) of the link between the two components?
BOB
You Crack Me Up Charlie !
Don Orr
>But I like your educational slant on the subject too.
Rob Wallace
Your next challenge......
Rob Wallace
>From a biology educator's perspective.....
...you should signal 'fusion' by having the ovum (now a zygote) light up when the sperm reaches its endpoint of travel..... perhaps a magnetic proximity switch in receptive area in the the ovum strapped to a few high output LEDs inside the ball to make it glow - a small rare earth magnet (neodymium) in the head of the sperm could close the switch.... Would drive home (no pun intended) that the deed has been accomplished.
Now the most complex - having several million sperm all competing for the same ovum... ...now that's a party!
Rob Wallace
charlie belden
>The connection between the two components is the power cord from the battery pack in the Ovum to the little motor in the Sperm. The power cord tethers the Sperm component to the Ovum component. Because the Sperm component is tethered to the Ovum, it will, regardless of its initial direction, eventually be drawn to the Ovum. I guess I could try painting the power cord with pearlescent white - if the paint will stick to the wire.
I couldn't find any two strand wire that was any smaller and yet still flexible enough to work. And the RED Power Button (the hormonal switch that, once turned on, starts the Biological Imperative) had to be on the Ovum component since females enter puberty a bit earlier than males.
The ideal set up for this idea would be a lot trickier to do - an infra red detector and micro controller in the Sperm component, along with batteries and motor, and an infra red sending unit on the Ovum component. The Sperm would be programmed to Follow The Beam. (Think Roomba robot vacuum cleaning thing homing in on its charging station when its battery gets low).
This was a Wild Hare Idea that took a bit of thinking and planning - before getting to the lathe.
1:1 scale drawing of motor and Sperm
Bob Macgregor
>I suspected that it might be a power cord, but wasn't sure. I have seen some pretty thin cords (speaker wire?) with clear insulation that might be somewhat less obtrusive, but I don't know if they are as flexible as you need. If you found a white or off-white, twisted cord, you could say it was symbolic of the double-helix of DNA...
BOB
Peter Rand
>congratulations! you did it!! quite a trick. quite an issue. quite a piece
