Your opinion!
Wesley
>I would like an opinion on the, Laguna 18/47 lathe. I am comparing it with the Powermatic 3520B. Does anyone have this lathe? If so what is
your experience with it?
Your opinion!
Wesley
Any Laguna owners out there??
Thad
Re: Your opinion!
Frederick Nelson
>Just got one, actually. Haven't even powered it up yet. My electrical panel is made by a "no-longer-in-business" company and I had to order the new 220 volt breaker on-line. When it comes in, we'll start turning. (I expect it tomorrow.)
It seems to be well-made, no skimping on the cast iron, and fit and finish seem to be of good quality.
The one (and so far only) complaint I have about it is that there are no instructions for assembly. It isn't hard to figure out, however.
This past Saturday ("How did you spend YOUR Fourth of July?") was spent moving it into the basement and assembling it. It went together quickly, but I would recommend simply un-threading the nut on the bottom of the tailstock, toolrest base, and headstock, rather than trying to slide them through the opening at the end of the bed. It is also heavy, about 500 pounds, so get lots of help with assembly.
I'll have more to say once I get the electrons moving.
Fred
Under clear skies in Eastern Missouri
Re: Your opinion!
>I saw it at the IWF. IMO, it might be better to compare it with the Jet 1642 EVS-2. It is less expensive than the Jet.
If this lathe had been available when I bought my Jet 1642, I would have purchased it. The 47" bed length is great for long spindles.
Re: Your opinion!
Texian
>Fred,
Assume you mean that you got the Laguna 18-47. Others will be very interested in how well you like it, if any problems develop, and if so the quality of the resulting service. Please keep us posted.
Re: Your opinion!
Frederick Nelson
>Yup, that's what I meant.
Here it sits, awaiting power, with the tail end of my old lathe in the lower right corner of the picture.
Fred
Found a thread... *LINK*
Thad Parker
>...covering the Laguna over on AAW with links to lengthy discussions of the lathe & customer support.
From the responses to the thread above, it'd make me reconsider the Jet.
Laguna Thread on AAW
Re: Your opinion!
Texian
>Thanks Fred. It seems reasonable to assume that Laguna has been working hard on product quality and customer service quality since the plethora of negative comments on various turning forums. Hence you may indeed have a dandy piece of equipment and a good value for your $$. Please keep us posted. After a week or three of intensive use, you could post a review of your new lathe.
Re: Your opinion!
Bob Macgregor
>The PM 3520 was my first choice lathe, too, but buying it, delivered, in Canada was going to nearly double the US price. I ordered one of the Laguna 18/47 lathes, but Busy Bee Tools came out with a nearly identical unit about the same time, so I cancelled the Laguna order and switched to the BB (as did many other Canadian customers).
As far as I can tell, there are three major differences between the Laguna and Busy Bee (Craftex) lathe. The Craftex has a 1" spindle, green paint and a much lower price ( note that prices are in Canadian $$. http://busybeetools.ca/cgi-bin/picture10?NTITEM=CT128 ).
Although I (and I believe other owners of the CT128) have been really satisfied, both with its performance and Busy Bee's service, it would be pretty difficult to get one of these in the US. In addition, I suspect BB might also be less service-oriented for a US customer (they do not market to the US; sort of the mirror of my problem trying to get a PM 3520 here).
I don't mean to tease you about the good deal we have (for once!) in Canada on this lathe, but, if the Laguna is really essentially the same lathe as the Craftex 18/47, just in different paint, and if Laguna is now paying better attention to customer service than some early threads suggested was the case, it could be a good, solid performer for you. If, while you are trying to make up your mind, you hit the lottery jackpot, go ahead and get a PM or Robust or whatever, but the price of the Laguna is pretty good for its features (though the Jet and Nova lathes aren't too far off in price, if you are nervous about the Laguna reputation).
BOB
? about the CT128
Steve Kubien
>Hey Bob,
Can you tell me what the travel distance is of the tailstock quill on this lathe? The website says 2" but the Laguna says 4" or 4.5". I too believe these are nearly identical machines so I wonder if there is something wrong in the print.
Cheers, eh!
Steve
Ajax, Ontario
Re: ? about the CT128
Bob Macgregor
>Steve, I noticed that too, and I don't think it is right. I'm not at home, so I can't double-check right now, but I think I've drilled considerably deeper than 2" in one pass before.
If nobody else speaks up on this, I'll try to remember to crank it all the way out and see (the quill has scribed calibration marks on it).
BOB
