How much difference is there between...
Paul Zerjay
>the 5/8" and 3/4" Kelton hollowers? I know it's 1/8", but will that 1/8th give much more depth?
Paul Zerjay
Re: How much difference is there between...
>Paul I can't tell you about the 5/8 vs 3/4 but with my homemade tools I can hollow down to about 8 inches with the 1/2 and 12 to 14 with the 3/4 so I would imagine the 5/8 would fall somewhere in between.
Mike Peace
>I have seen a rule of thumb of 15 X tool diameter is about the maximum practical depth for using a hollowing tool. So, that would be about 1 7/8" difference.
Paul Zerjay
>John, Years ago when I made my captured boring bar rig, I made the d-handle from 1" black iron pipe. A 5/8 round bar will slide nicely inside the pipe. A simple set screw holds it in place so you can telescope it out as far as you need. Also the handle that comes with a McNaughton coring system will accept a 5/8" round bar as well. I'll let you know the max depth I can reach with 'em.
