>I'm looking a better method of drying green rough-turned bowls. I currently put them in a paper grocery bag, stuff the shavings in the excess space in the bag and let sit in the basement for 6 months or until I get back to them.
>First, you have to turn at least 50 of the hundreds you have stored in grocery bags? I saw them and I lost count at 300...8)
After you do that you will not want to rough out more bowls and store them....
Whatever works for you is good. The alcohol method works but is messy and expensive; just piling them on the floor like Elvie does works for him; boiling them works for other folks. I like the alcohol method but I don't turn many bowls. It works great for boxes.
>Mike, you sound like my wife. She thinks I have to many in bags also. I finished off one Friday at Frank's, but I roughed out another one yesterday so my pile would not look like it was getting to small. lol
>I made a couple of drying crates, 24" x 24" x 24". I made them from resawn 2 x 4s so the slats are 3 1/2" wide spaced a a couple of inces apart. They are similar to the produce crates that were around when I was a kid.
I rough out the bowl, coat it with endgrain sealer and put it in the crate upside down. The crates are raised off the floor 1 1/2" so there is airflow from the bottom and sides. I stack bowls until the crate is full and then move to the next one. If I were to worry about the drying rate, I would wrap the whole thing ing kraft paper. But, so far the bare crates have worked fine. They are in a corner that does not get a lot of airflow, so there is no rapid drying.
>I coat mine 100% with Anchorseal, lose stack them on a shelf in the corner of my shop and forget about them for at least 6 months. Provided I didn't break any rule about where to cut the wood from the tree, maintain a uniform thickness when roughing, and seal them within a few hours of turning, I get very little fall-out.
Just gotta get used to turning up a lot of bowls when the wood becomes available, and having that 6+ month lead time when a bowl is needed. I typically have 50 or so on the shelves of various sizes waiting for finish turning. Once your inventory of drying bowls is built up, just maintain it. Once dry, they can sit for years and not get any worse.
