Power sanding - 2" or 3" pads?
wilbur
>I want to give power sanding a try. My bowls so far have been 9" diameter max. I'd love to get some input as to whether I should get a 2" or 3" sanding pad.
Obviously, the advantage of the larger pad is being able to cover more area at once. The disadvantage of the larger pad, I'm guessing, is fitting into tighter curves. But then I learned about innerface pads, and was wondering if a larger pad with a very soft innerface pad can get into a tighter curve.
Any comments would be greatly appreciated.
And here's a bad picture of the last bowl I made, just to give you all an idea of the type of shape I gravitate to.
