Power sanding spindle-work?
Steve Kubien
Steve Kubien
>I've been reading the thread Wilbur started about 2 or 3" sanding discs for power sanding. It must have stirred something in my brain because I chose to use 3" discs on my drill to power sand a peppermill yesterday.
Does anyone else power sand spindle work? For flowing lines, I will be ddoing this a lot more because it is so much quicker.
Cheers,
Steve Kubien
Re: Power sanding spindle-work?
Ray Binnicker
>I power sand everything possible. I start out with the lathe in reverse, next grit the lathe is forward, the next grit is reverse, etc. It is quicker ( I thought I was just lazy) and I believe I get a better finish.
Ray Binnicker
Ed in Leaside
>I been known to take a belt sander to a long skinny piece of purpleheart. ;)
Jim Shaver - Oakville, Ont, Canada
>I thought that long skinny purpleheart pole was slow roasted on your special tracking shaper?
Jim
Keith Tompkins
Keith Tompkins
>HI Steve, There shouldn't really be a need to power sand spindle work...the biggest problem is that fine details will become obscured by the sanding. Traditionally, details such as beads and coves are approached with sandpaper, but the filet areas are never sanded in order to preserve crispness. By finessing your tools,and using good technique, you can work on refining your shapes, which leaves very little sanding work to do.
Steve Kubien
Steve Kubien
>No disputing anything you said Keith. A moment of "Oh look, something shiny!" resulted in a nasty catch. I resorted to a 3" x 120grit disc and was just really impressed with the ease and speed of it all. The peppermill has a long flowing curve, no beads, fillets etc. Very little fine detail. No, power-sanding details would not be good at all.
Cheers,
Steve
>I agree with Keith. I turn a lot of spindles. I have power sanded large spindles. I'm talking 5" thick or so. The surface speed of the wood will get to you on these unless you slow the lathe down. On all smaller work a hand sand under power and then stop and hand sand with the grain on the longer smooth areas. It goes very fast so I don't see a need to power sand.
