overhead camera
overhead camera
overhead camera
Jeff Brockett
>I am looking for a source to purchase a small fixed lense overhead camera that is hdmi capable that we can use for club demonstrations. Main camera we use is hdmi and the switch box requires hdmi. If you know of a good source to purchase this camera I would appreciate the information.
Re: overhead camera
Woodchuckers
Jim Shaver - Oakville, Ont, Canada
>I know at the GHWG we have cams from John at www.woodchuckers.com
I'd give him a call for sure.
Take care,
Jim
Re: overhead camera
Woodchuckers no longer has them *LINK*
Mike Brazeau
>John at Woodchuckers no longer has the small cameras. Check out the sources of surveillance or spy cameras on the net. They are fixed focus and available at quite low cost. That is basically what John was using. The one at the link I have provided looks very similar to the one we use at the GHWG. I picked up a B&W version with infra red LED lighting for under $50 Cdn recently at a liquidator locally and they had color versions as well.
Miniature color camera
Re: overhead camera
Re: overhead camera *LINK*
Mark Wollschlager
>HDMI output makes it a pretty small world.
The is the one I found with a direct HDMI output.
Pretty much anything else would have to go through a converter.
The converter might be the best in the long run, as you can mix and match the mini CCD cameras with your main camera.
Single input composite => HDMI converters can be had for app $100.
http://www.hdtvsupply.com/composite-to-hdmi-scaler.html
Hope this helps.
Mark.
Seiwa America HDMI digital monitor output camera
Re: overhead camera
Re: overhead camera
Jeff Brockett
>Thanks for the suggestions. I will check out the sites and see what they have to offer.
Re: overhead camera
Re:NTSB will work just fine, and source...
Jamie Donaldson
>... I have been using for the Woodchuckers replacements for AAW come from 123CCTV.net and cost $86 last time I checked. I would also suggest that a mini cam on a stand ($20)is much easier to use and move than all the overhead stuff.
Re: overhead camera
Re:I have posted a complete tutorial....
Jamie Donaldson
>...for this type application under the AAW "Chapter Best Practices" area of the AAW site. An update is for the JVC JX-66 3 channel switcher available for about $36.
