>I want to give power sanding a try. My bowls so far have been 9" diameter max. I'd love to get some input as to whether I should get a 2" or 3" sanding pad.
Obviously, the advantage of the larger pad is being able to cover more area at once. The disadvantage of the larger pad, I'm guessing, is fitting into tighter curves. But then I learned about innerface pads, and was wondering if a larger pad with a very soft innerface pad can get into a tighter curve.
Any comments would be greatly appreciated.
And here's a bad picture of the last bowl I made, just to give you all an idea of the type of shape I gravitate to.
>Wilbur, Conventional wisdom says to use the largest pad that will fit into the piece. For a 9" bowl, 3" pads will do nicely.
Power sanding is great, and you'll love it, but it's not automatic. You have to learn how to do it. Here's a hint or two:
A variable speed drill is mandatory. SLOW is the key word. If you run the drill fast, you will burn up your pad. I power sand at about 100-200 RPM with the lathe OFF. I can almost count the revolutions of the pad. Even so, I get lots of dust, which means the sandpaper is cutting.
Sandpaper doesn't cut faster at a higher RPM. It tends to skid across the surface, generating a lot of heat in the process. Some say it even cuts more slowly at high RPM.
Sandpaper should not leave the wood shiny, unless you are well beyond 600 grit. A shiny surface means you are burnishing the wood instead of sanding, and burnishing doesn't tend to remove scratches.
If slow sanding doesn't remove scratches promptly, go back to a lower grit. With any grit, you should see dust being generated. If you don't, something's wrong, like dull sandpaper, or running the drill too fast.
Buy one of those crepe sandpaper cleaning sticks. They are quite effective. Because of the expense of the disks, you will quickly get your money back. A crepe-sole shoe will work just as well if you can find one.
I think a reversible drill is essential. At some angles on curved surfaces, the disk will tend to grab the wood and bounce, making it almost impossible to control. Reverse the drill, and all will be well.
Don't try power sanding with the lathe running until you get quite a bit of experience. There's really no reason to have the lathe running.
>I'll add one other tip. I keep a file card handy. One of those wire brush things used to clean a file. Some woods tend to clog sandpaper really fast and of course green wood does also. You can run the paper over this file card and get rid of the clogged up gunk.
I use 2" because I feel they pads reach into corners and details better. For really fine details I use hand held sandpaper either folded or glued to sticks. I like the tapered mandrels that are stiff because I can reach into the foot areas. I know some people like the really soft pads but the stiffer ones work well for me.
I like the blue disc from www.vinceswoodnwonders.com and also the blue discs from www.thesandingglove.com The discs are larger than 2" so I buy the interface pads from Vince that are larger. This paper is really good.
>Nice bowl. Looks a bit thinner than most of mine. I use 3" disks on most everything except small stuff. Larger disks simply sand faster, and smoother, IMO. Also, smaller disks overheat easier and have less gripping surface on the Velcro pad. I do slow the lathe down from normal turning speed and use a variable speed, close quarters drill. A dust collector and a good mask are very useful, as disk sanders can kick up a lot of dust.
John already mentioned Vince Welch's site. Go there and read through his information. Very good procedure for power sanding. His starter packs are a good bargain to get you into effective power sanding. I got his system and followed his advice and it totally changed how I sand. I get much better results now.
I use 2" for smaller bowls and 3" for larger work. Blue discs are very tough and last a good while if kept clean.
>Thanks Doc and John. Excellent advice. One thing I might add is that I sand with the lathe running but at a VERY slow speed. I reverse my lathe direction each time I change grits. This helps remove the tiny fibers that tend to lay down in one direction relative to the rotation.
>A 3 inch pad has twice the surface area that a 2 inch pad does. If I can get a 3 inch pad inside the bowl, I will use it. You only want the soft pads on when you are using the higher grits, 220 and above. The rounded edges of Vinces interface pads let you get into most places. I do sand with the lathe on, but at speeds of 20 pm or so. My bowls are warped, and you can't keep a drill or your hands on the wood at anything over 50 rpm. Slow speed on the drill as well. It doesn't really make that much sence to me, but slower does work better.
>Like others, I use the largest disc I can. As Reed mentioned, a 3" has actually more than twice the surface area of a 2" (by shortening "pi" to 3.14; a 2" disc would be 3.14 sq. inches and a 3" disc would be 7.065 sq. inches). I really like the 3M purple PSA discs (a ten pack will last as long as a 50 pack of the standard discs and only costs $6.95 compared to $11-$13 for a 50 pack, the PSA discs goes to 220 and then I've been using Norton discs for 320 and above, all of which from www.thesandingglove.com. I do also change directions of the lathe, which is running slowly, when I cahnge grits. Since the majority of my bowls are to be used, I do sand to the highest grit, mist with water, and sand with the grit again after it dries. This raises the grain and sands it off so when the bowl is washed the grain won't raise.
Here's an excellent video that Mike Mahoney has added to Youtube from his "bowl basics" dvd on the subject of power sanding.
One thing I have gotten in the habit of doing while power sanding is blowing off the sanding dust between sanding discs. I have compressed air at the lathe and between each grit I will blow the dust off the disc and the work piece. Don't know how much difference it makes but I've got it justified in my mind. It just makes sense to me to get the larger grit dust off before going at it with a smaller grit disc. Some others may have different opinions.
>Great. Now I have to get a compressor as well. :@)
Actually, I have been blowing the dust off my workpieces between grits when sanding by hand. Of course, I also forget that I have my faceshield on at the time, so any effect has been pretty minimal. :@)
