Coloring and liming ash....
Mike Stafford
Mike Stafford
>A few weeks ago I had the chance to work with Bob Moffett's club, Piedmont Triad Woodturners and do a hands on session.
Bob told me in advance that we would be using ash so I tried to pass on some coloring and liming techniques that I learned from Ed Moore.
Here is the box I dyed black and limed during the hands on session. After returning home I dyed it again and limed it again to deepen the effect.
The box is ash and is 2 1/2" tall and 3" in diameter.
In following posts I will show some results of other trials.
Re: Coloring and liming ash....
Mike Stafford
Black dyed and limed ash mosque box...
Mike Stafford
>Here is another black box, double dyed and limed.
It is 4" tall and 2 3/4" in diameter.
Mike Stafford
Green dyed and limed ash....
Mike Stafford
>Here is another experiment using green dye and liming wax.
This box is 1 3/4" tall and 3" in diameter.
Mike Stafford
Red dyed and limed....
Mike Stafford
>Here is the most unsuccessful trial in red dye and liming wax. I had a difficult time with this one and I wonder if my dye had gone bad. It was also the most difficult to photograph and have the liming show up.
This box is 3 1/4" tall and 2 3/4" in diameter.
Comments are welcome on all of them.
Re: Red dyed and limed....
Bob Rogne
>Mike
I have never dyed or limed? These look great how is it done.
Thanks
Bob
Russ Fairfield
>Mike,
You will have better luck with Red if you bleach the Ash first. Otherwise it gets dark and blotchy like this one.
Ed Moore of SW VA
>Mike,
Of all the boxes you have posted in this thread I like this box the best. I love its simplicity and the flow of the lines. Old friend, you nailed this one. Excellent!
Ed
Re: All are way cool Mike, and what.....
Jamie Donaldson
>...kind of dyes are you using? I'm becoming more interested in the dying processes, and to shorten the learning curve have signed up for a dying class at the Folk School in Sept. with Gary Sanders and Frank Penta.
Jim Shaver - Oakville, Ont, Canada
>I like them all Mike,
Are you using analine dyes?
Tak ecare,
Jim
Mike Stafford
Mike Stafford
>Jamie, these are aniline dyes dissolved in alcohol. In most instances I applied two coats to get a uniform color. I was told by Ed to allow the dye to dry between coats to get more uniformity.
You will enjoy the class with Frank if you can keep him on task. He tends to wander a bit sometimes but he is a wonderful teacher. He and I discussed this technique at our recent meeting and I was telling him of the method Mr. Moore taught me which he found interesting and slightly different from the method he uses.
Thanks for the comments.
Steve Kubien
All are great...
Steve Kubien
>...but this one is simply stunning! I mistakernly bought black wax thinking that was liming wax. Oh well. Eventually I'll get around to the real thing, specifically for all of the small pieces of ash that tend to come my way.
Cheers,
Steve
Mike Stafford
Mike Stafford
>Bob, the process is simple but somewhat messy. Essentially you turn and finely sand your object and apply a dye. In this case I used an alcohol based aniline dye made up fairly strong as I wanted deep rich colors. I applied the first coat and let it dry very thoroughly. Then I rubbed it down with a white 3M pad to remove any raised grain. After that I applied another coat of dye and let it dry. This coat was also rubbed down with a piece of cheesecloth to remove any excess surface dye. This was followed with a very light coat of rattle can lacquer to help prevent the liming wax from sticking in all the pores on the wood. You really only want it in the large pores and veins. Then I used an old piece of T-shirt to apply some liming wax carefully rubbing it into the grain. Using another piece of T-shirt I removed all the excess wax rubbing across the grain so as to not disturb the wax in the open pores. I allowed the wax to dry and then I applied another coat with the grain and repeated the across the grain removal. Finally I used some clear wax, i.e. Johnson's paste wax, to remove any remaining residues not in the open pores. I polished this to a high shine and topped it off with a little Renaissance wax just for the extra protection.
Some dyes worked better than others and based upon what Russ said I have some more things to try and hopefully end up with more consistent results.
Thanks for looking.
Mike Stafford
Bleach with what Russ?
Mike Stafford
>Would my results improve with the other colors as well?
Since I am just messing around I might as well learn what I can and see how best to do it.
Re: Bleach with what Russ?
Russ Fairfield
>Klean-Strip Wood Bleach is the one I use because that is what the local Ace Hardware has in stock. Bleaching helps all of the transparent colors such as red, green, and yellow.
>Jamie I've seen Gary do a lecture on dyes. He's very good and quite knowledgeable. Also a great turner.
>Mike They are all really sweet. Glad your having fun with dye. I'm about to take a new direction ans see if I can afford to work with the metallic dyes. They have a much less light fading than other dyes. I just have to convince myself to make the plunge.
mfoster
>Mike, these look like a lot of fun to do. I've never tried liming, but the result looks great. BTW, nice form on the boxes to start.
Jamie, I am also signed up for the class with Frank. My wife and I have been wanting to take a class at the Folk School and see a bit of SC for a couple of years. We finally found a week that worked for both of us. She is taking a course in weaving and I thought that working with someone more experienced in coloring than I am was a great idea. It is now even a better idea since you will also be there. I have admired your work for a long time, and it will be great to meet you and get some turning time in with you.
Mike
WayneLeach - NW Ont
>Mike,
I have been admiring the boxes you create for some time now. I really am impacted by these as black ash is the only wood I have available that has any character and some of the dyed versions really give the grain a stunning appearance. Thanks a bunch for sharing this with us.
Regards,
Wayne
Dyes Fade?
Doc Green
>Gary Sanders gave a demo at our club (Greensboro, NC) and about the first thing he said was, "Dyes fade" and he had samples to show it.
His recommendation was to use artists acrylic inks and Higgins inks, both water soluble.
I've seen a lot of interest in dyes lately, and wonder if this fading thing is being considered. ~Doc
Re: Colorfast and fading *LINK*
Russ Fairfield
>There is always a lot of talk about fading, but fading is a relative thing that depends on a lot of factors - the type of dye, the solvent, color, light brightness, light color, ambient temperatures, and polutants in the air.
Fading isn't usually a concern within the life of a woodturning and where it is kept. An an example, a piece that will fade in a week in direct bright sunlight in mid-summer, would be colorfast for years inside of our home where all sunlight is filtered, and for decades in most livingrooms.
Everything I know about dyes, which isn't very much, is discussed in an article on my website. It may be of help.
Coloring Wood Turnings With Analine Dye
Don wilcut
>I've also signed up for the class with Gary and Mike. I just attended a Platter class with Mike and assisted Gary in one of his classes years back in one of the Nationals. See you there.
Don
light wood colors better
>Mike many woods are pretty yellow when a finish is applied and it mutes the colors of transparent dyes. I will often bleach the wood very light so that I have more control over the final color. I use Klean strip wood bleach that I buy at my Porter Paint store. It might take as many as 10 bleachings on some woods. You can even lighten walnut to almost white.
Some woods do weird things with bleach so always test first. I tried to bleach osage orange and it went barnwood gray. I tried to bleach a thin cedar bowl and it blew up on me. The bleach penetrated so fast and the wood expanded to quickly and it cracked into about 8 pieces. Next time I'm going to soak the bowl in water first to even out the bleach penetration.
Great work Mike
Don Orr
>I actually like the red one a lot !
Bob Moffett
Bob Moffett
>Great job Mike! How did you finish the inside of these boxes?
Jennifer@Indy.USA
>Love this new look Mike!
