>To me, these look like balls of Tubificid worms, sometimes called "sludge worms". What you're looking at isn't one organism, it's hundreds. When one contracts due to disturbance, the movement triggers others to move as well, causing the "flexing" appearance.
Then again, I could be wrong. Regardless, they are not very appealing, to be sure.
>I agree with Dave - they are segmented worms (annelids) and NOT bryozoans. I think nearly every sewer system has these kind of worms by the millions and billions, and this is nothing to be concerned about. This would be a very unusual habitat for bryozoans - it is unfortunate that the organisms were misidentified.
>I did a little research on the web and I think that the name Byrozoan was misapplied here. I will not be the one to tell the biology professor quoted in the article that he is wrong since I am not a biologist and I do not play one on TV so as far as I am concerned they are a precursor to the BLOB. 8-))
Here is what one source said:
"Tubifex tubifex, also called the sludge worm, sewage worm, or lime snake; is a species of tubificid segmented worm that inhabits the sediments of lakes and rivers on several continents. T. tubifex probably includes several species, but distinguishing between them is difficult because reproductive organs, commonly used in species identification, are resorbed after mating, and because external characteristics of the worm vary with changes in salinity. These worms ingest sediments and gain nutrition by selectively digesting bacteria and absorbing molecules through the body wall. The worms can survive with little oxygen through the use of their hemoglobin rich tail-ends, which they wave in order to absorb what little oxygen they can. They can also survive in areas so heavily polluted with organic matter that almost no other species can endure. By forming a protective cyst and lowering its metabolic rate, T. tubifex can survive drought and food shortage. Worms living in sewers can enter a home through a drain or toilet. Care should be taken as the worm(s) can transmit a variety of bacterial infections. Encystment may also function in dispersal of the worm."
The last two sentences of the paragraph above are interesting to me. How many of you have dogs who drink from the toilet?
