ADVERTISE HERE - FREE TRIAL
Sharpening chain saw on machine
Aage Rendalen
Aage Rendalen
>I followed somebody's advice on this site and bought a wall/bench sharpener from Northern Tools. I tested it out on an old chain and discovered it was not as easy as it looked like. I started out with the setting given for my Stihl 26RMC3 chain: 30 and 85 degrees but apparently my test chain required a different setting for the teeth look blunt rather than sharp.
How do you work out the settings for an unknown chain?
Also: any general advice on using these sharpening machines?
Re: Sharpening chain saw on machine
Ken
>I'v been sharpening them for a while,an it may be easier for me,but I usually just eyeball the wheel up with the teeth and then bring it down to where it slides in the grove in front of the tooth,then adjust the stop on the grinder as to where the wheel just barely touches the tooth.You may be a tad of on factory spec's but all the teeth will be sharpened at the same angle and it should cut well for you.
Ken Oakley-Sunny St. Cloud, Fla.
>I take mine to the local Stihl dealer. $4.00 to sharpen any length chain. Plus there is always a box full of chains that people never picked up that cost $5.00. Can almost throw them away when they get dull at that price.
Dick Hines
Dick Hines
>It's hard to beat the old hand file for sharpening a chain. About once a year I take mine in and have the dealer touch them up.
Dick Coers
>I have the chain holder rotated to 30 degrees, and the head tilted to the 55 degree mark (35 degrees off vertical) on my machine. I usually take about 3 mini pulls or strokes of the grinder on each tooth compared to just pulling the grinder head down. I think this limits the heat put into each tooth. I often dress the grinding wheel to keep fresh abrasive at the cut. This also limits the heat in each tooth. Another thing I like to do is hand wire brush the chain before sharpening. This cleans off the oil and sap so it will not contaminate the grinding wheel.
I used to take mine in for the $4 grind service, but I get at least twice the life on the chain since I started grinding myself. Those guys seemed to set their machine pretty heavy. They are in the business to sell chain after all.
Four bucks?! Where? They charge eight here.
adrien
