When is a 1" post not a 1" post?
Dave Mount
>Answer -- when it is a Grizzly.
I bought a Grizzly G0462 (think that's the number) lathe a few months ago. All in all it is about what I expected, a lot of tool for the money, but it has it's "features." But a review of that lathe is not the purpose of this post.
I decided I needed a curved rest and spied the Delta curved rest for only $24.95 at Packard, so I ordered it. When I went to drop it into the Griz (advertised as having a 1" post) it wouldn't fit. I got out the calipers and found that the post of the Griz rest measured about 0.980" (which is essentially 25 mm, and it fits snugly) while the Delta is about 0.998 (I say "about" because neither one appeared to be exactly round).
I actually have access to a 1" metal cutting twist bit, so I'm about to try to ream out the hole to a full 1" on the drill press (with everything securely clamped, believe me), believing that after that surgery I'll be able to use both rests. Anyone want to tell me that's the wrong thing to do and/or give me a different way to go?
Thanks.
Dave
Re: When is a 1" post not a 1" post?
Give It A Brake
>Actually a brake cylinder hone to enlarge but maintain the round instead of a twist drill that will be hard to control. If you do the drill, use minimum speed.
Re: Not familiar -- like this? *LINK*
Dave Mount
>Hi Mark--
I'm afraid that's a new tool to me. Is the link below to the right thing? I see others that have small stones on what appear to be pivoting arms. Do you just put it in the hole and turn it with a drill until you come up to the diameter you want?
Thanks for the pointer. I am a little concerned about what'll happen if I drill it out, though I can slow my DP way down. . .but if this'll work better. . .
Best,
Dave
Link to 1" brake hone
Nope
>One I used is a rig with 3 spring-loaded stone "shoes" that expand in the bore. They come in different grits and sizes.
Of course, a friendly machinist might just bore it out for you in about 5 minutes. Helps to make friends in the trades. Especially ones who get paid quickly and also get a bonus of a nice bowl or jar to take home to the S.O.
mm
>Ideally you need to ream it to 1" for the best accuracy. A cylinder hone could feasibly go out of round but for a tool rest banjo I would think the drill would work. I did that on my floor mounted stand it it worked fine. That was before I had my metal lathe and mill.
You may be able to rent a brake cylinder hone from one of the automotive parts stores but they are pretty inexpensive.
Steven Antonucci
Keep it simple
steve antonucci
>I'd probably mount the tool post in my chuck and file/sand paper the post. I've done it before on a homemade toolrest and it is very controllable. Sand a little, test fit. stop when the post drops in. If you only need to remove .008 +/- it should take less than a minute
Steve
Re: I'm confused *LINK*
Dave Mount
>I like the idea of sanding the post instead of drilling the banjo, but I'm confused about how I would chuck this thing so I could sand the post where I need to (the bottom two thirds). Seems to me I would have to grab it by the end of the post, which would preclude me sanding the lower portion. Am I misunderstanding something?
It's a one-piece rest, shown at the link below. You wouldn't have to tell me twice to be careful with the business end of that thing spinning around. . .
Thanks.
Dave
Delta French Curl Tool Rest
Re: I'm confused
>Dave clamp the top to a work bench. I did as steve did on one of mine. Wrap the paper around the bar and just pull back and forth like you shine your shoes.
Sanding Steel or Iron
Doc Green
>I recently filed/sanded a nail to reduce its diameter from 0.110 to 0.103" and it was a slow process, on the lathe. Probably took me 15 minutes or more, with frequent stops to measure the diameter. I found 100 grit sandpaper the most effective.
~Doc PS: I was making a pin for a pin chuck. Worked! :)
Re: When is a 1" post not a 1" post? *LINK*
Dale Stansbery
>If you want to open the hole up, I'd suggest looking for an adjustable hand reamer. If you have any machinist friends, they may have one of appropriate size. The reamer has cutters along it's length that expand when you tighten a nut on the end. it's hand turned like a tap so you can go slow and carefully sneak up on the diameter that just fits.
http://www.newmantools.com/reamer/expanding.htm
